reactor
After moving a few months back, I removed the new Frigidaire dishwasher and replaced it with a near (but not quite) vintage GE Tower Wash. I posted pictures of one of my first Bob-Loads.
The dishwasher, then had the newer active filtration. Great for very small food particles. I tested it with my favorite test of one cup of used coffee grounds. Cleared the water up very fast. BUT the problem with the
newer filtration systems is that they use a loose ball (just slightly larger than a marble, as a check valve in the food particle collection chamber.
I have had horrible times with this filtration system causing the dishwasher not to drian. Large food particle get between the ball and the ball seat and keep it from sealing. Hence, no draining of the machine. I have seen many of these on Craigslist and Facebook Marketplace where people are selling them saying, "Doesn't Drain."
So, I had an old GE with the good old, an exceedingly reliable, passive filter. I removed the door of the machine and put it on the older GE body.
Now it drains, as it should..
(PHOTOS GOT A LITTLE OUT OF ORDER, NOT ALL GO IN ORDER FROM DIRTY TO CLEAN, HA)[this post was last edited: 11/24/2021-15:39]
