another laundromat question
christfr
Aug 25, 2002
1,786
st louis mo
well here we go again. have my L5 apart again to change its oil and mess with the belts. i went to check the bolts-screws the hold on the water pump and found the pump had frozen up. so off and apart came the pump. i have the pump apart and i guess from the water going through there it has sort of ate up the metal housing to the point that there is a tiny pin hole that lets water into the shaft and i guess from sitting it made the shaft freeze up. i have the shaft out and am trying to seal the pin hole and regrease the shaft. but i suppose it would be a good idea to start looking for a diffrent pump. so here is the question does any one know of a used pump for sale?
this old girl and i would be more than happy to buy one. any ideas? thanks chris
