philr
For a while, I've been searching for a 1961-62 Custom Imperial 30" range. I finally got one. It needs a few minor repairs but it's in nice shape and the former owners took great care of it.
Unlike 1961 Custom Imperial, the 1962 lacks the french doors but it's ok for me.
It's got a working clock/timer too! The oven does need repairs as the wiring that goes to the lower element burned. The failure was probably (or should I say certainly) caused by bad contacts on the removeable lower element. It seems to have all the correct burner switches and the electronic heat minder still seems to work fine.
Being a Canadian model, it lacks the Speed Heat and it has two "Surface" lights instead of one but otherwise, it's almost identical to the US ranges. I think it's one of the very last of Canadian ranges that were closely looking like US models. In mid-1962, Frigidaire Canada introduced a new lineup that was quite different. Previously, there were just a few economy models that were different from the US versions but in mid-1962, all the 30" free-standing ranges, including the Custom Imperial model, were replaced with Canada-specific models with fuse panels moved from under the oven to under the control panel.
[this post was last edited: 8/19/2013-00:25]
