Anyone know how to remove this hose from a Whirlpool/Kenmore belt drive washer?
maytag85
May 11, 2017
3,192
Sean A806
Trying to remove this hose from my 1963 Whirlpool Imperial Mark XII washer and I believe it should come out easily but I just want to double check so I won’t chance breaking anything. It’s the hose that’s apart of the lint filtering/dispenser system.
Here’s a picture of the hose I am talking about. It’s on the left side of the machine where the bleach and fabric softener dispensers are
that port is for the "J" hose that feeds the pump for the filter.....
and in your case, they incorporate another spout, to pull in from the dispenser...kind of a cool design as it would mix the solutions with water before introducing to the load...
just simple clamps and hoses......
some hoses may get stuck on there, so yeah, use caution when trying to remove them, that vintage plastic can snap...for the most part, if it aint broke, dont fix it...
It looks like I’ll take the tub out. Planned on taking the tub out anyways but I am scared I might end up braking the original Surgilator since it’s a Bakelite type plastic and if it does end up braking then I will be out of luck since I have no clue where to source those original Surgilators from.
