Anyone want an AMP?
swestoyz
Sep 27, 2004
6,634
Cedar Falls, IA
Item location: Dundalk, MD, United States
"Vintage Maytag Automatic Washing Machine. Very early model of Maytag Automatic Washer. Body in very good shape Has all original hoses, which would need replacing if you're going to use this on a day to day basis. This was my Great-Aunt's and I don't know if it still works or not but it's a great piece in great condition. Definitely a Maytag Collectible Piece It's heavy, bring muscle to move it."
http://cgi.ebay.com/Vintage-Maytag-...626928149QQcategoryZ71256QQrdZ1QQcmdZViewItem
Nice, and another AMP with a MINT rust-free lid, YAY! I hope someone saves this. I wonder why this particular machine has a white fill flume instead of the usual black? And since this is an early model, it probably has that "pinging" spin solenoid!
Those hoses will definitely need replacing as they are probably as hard as a ROCK! Interesting that the seller also didn't mention that it will need a new belt, the friction-drive pump is probably stuck and will need to be freed up and primed with very hot water, the T-key will probably need to be turned around, and the spin collar oiled...;-)
--Austin
Knowing those old maytags as we do, the timer is probably frozen as well. Timers are usually the first thing to die on a Maytag.
AMP AUCTION COMPLETE
I won~!
Hey, Veg...how's about you and I rendezvous and snag this puppy uppy!~
This'll be my first experience with the '49 AMP.
My goal is to take it apart and put it back together successfully, mainly, and less to use it, although I expect I will use it some too once it's back together!
Thanks for the heads up club members. I love this place!~
<hugs>
Bob
out of my car...
Got it home....now if I could just get it out of my car!
I think tomorrow after work I have a buddy who can help me get the AMP out of my 323.
The Maytag's in the Mazda for the night though, resting easily.
It looks WONDERFUL. Even has all the foot pads on it.
The belt looks pretty awful, however. Can any of you guys tell me if that's the same belt as on later maytags, or if the belt for the AMP is going to be a challenge to locate.
Thanks guys and gals for all your support.
Bob
Hi Bob,
The AMP uses the same transmission belt as the later helical-drive models, and like on the later 'Tags, it's a breeze to put on as well, with that pivoting motor mount! Before testing it with the belt, I would check, lubricate, and prime that friction-drive pump; how's the condition of the cork-covered wheel? If it seems worn, putting a Kirby vacuum belt over it will work great!
Luckily the pump wasn't stuck on mine, and I doubt it will be stuck on yours either, but it was a little stiff to turn. Prime it with very hot tap water and try to squirt some 3-in-1 oil on the impeller shaft. I had to take the wheel off first. Hold a small flathead screwdriver in the center slot and turn the wheel; it should come off easily.
Hope this helps...I also forgot to mention that if it shows no signs of life, replace the cord and it should fire right up!
--Austin
testing 123
Thanks for your suggestions, Austin, I do appreciate them. What's a friction drive pump? Cork wheel? I don't know those things!~
I'll go through and test what I can with a meter, and take things like the pump completely apart for cleaning and lubing, THEN I'll put water or electricity to it, after I think it may work right the first time. I'm not too new to vintage appliances, it's just that I've never worked on an AMP before. I'll need a new drain hose too, no big surprise, but I'm hoping the internal hoses are at least still useable.
I was graceously loaned a service manual for it this evening, too, by our own JeffAdelphi...so I have the secret de-coder ring, actually....Hopefully, I'll have it going like new again soon. It looks original and in beautiful condition for a nearly 60 year old machine.
Austin!
Austin, I'm VERY PROUD of you!!! Mark
Bob, the pump is energized by friction from the back side of the belt! Note how the belt comes off and replace it the same way. Enjoy your new machine!!! Mark
friction-drive pump
oh...Water Pump!~ got it~ and I have a kirby belt on hand and ready for cork wear issues should they present themselves.
Launderess - thanks - I'm bidding on that manual now!~
Kenmore 62 - must be some other machine in your memory..this one has a plain white plastic timer dial. You can see one in Unimatic1140's collection. A red pointer with a window sounds like a mid 60's Frigidaire to me - like a Rapidry1000.
Wonderful finds. Im picking up the white version of this washer with a matching ELECTRIC dryer this week! Gas Maytag dryers of this vintage with a pilot light can have burner problems that are not always safe to use. I speak from experience......have one with a burner that would not always shut off its gas valve when the dryer was shut off. Very dangerous.........the valve would stick internally, and even with the pilot out would continue to let gas seep out....needless to say, Im not using it anymore........
I am so glad that someone in the club got to save these. Congratulations Bob!
Hey Bob, great score. The 1949 AMP washer is a very rare find with the original can float inside the hollow red agitator.
Please keep us posted with the restoration.
Congrats, Bob! I musta just missed your post and email--I'd have LOVED to go with you to pick up (literally!) the sucker.
Phoo. My whole life is bad timing.
You're going to love this machine! Can't wait to see it in action.
veg
progress
O.K. It's inside the basement now.
All I know so far is the agitator comes right out and it is incredibly clean inside the tub - and I only have 3 out of 4 original foot pads.
The pump turns by hand and the cork looks good too. Even the belt may rejuvenate.
I hope to make big progress on it tonight, and will post photos later.
Robert - is that the AMP agitator on the home page of this site?
Thank you all for your support.
