Apartment size or not?
galwithaset
Jul 2, 2018
4
Savage, Minnesota
Hi,Gang. I just got this lovely Maytag A210 washing machine for free! It works, and it's in very nice condition. I just adore it! Sadly though, my husband does mot want me to keep it because he says it is "apartment size". I know it is a little petite (25.5 inches wide). Does the "A" in the model number mean "apartment size"?
Its the same vintage as my 1984 LA511. I bought it new and the matching DE410 dryer and only 1 repair on the washer in all those years. That is an old school Maytag washer inside and will run for you a very long time. If you can fit it, keep it because you will never find a newer model as good as this one. The A on mine means it is Almond finish.
That is at the minimum a 14 pound large capacity Maytag washer.  14 pounds is what normal washers (family-sizzed) held in 1963 or 1964.  It's a full-sized washer.  Maytags were narrower than belt-drive Kenmore or Whirlpools because of mechanical design.
Look at the agitator, if it has 4 of those vertical slots going up and down in it then it is the "Extra Large" Capacity machine, if it only has 3 then it is the regular capacity machine (a shorter tub and agitator) The Extra large capacity has the deeper tub and taller agitator and is just about as big as the Whirlpool Kenmore Super Capacity machines were and should handle your largest loads just fine. Also, you should know about the lint filter, if you pull out the fabric softener cup (if it's there) then pull the top cone of the agitator out, it will come out to reveal a circular screen that collects lint. It needs to be checked after each load. Most of the time lint about the size of a quarter collects on it but if you wash something fluffy or new, it could be loaded. If it won't come out, chances are someone previous didn't know about it and it's stuck in place from mineral and lint buildup. The way it works is the agitation action pushes water away from the fins at the bottom, water flowing through the agitator falls down through the lower holes in it creating a void in the center of the agitator that is then refilled with water flowing in through those slots in the center post, the round screen in the center post of the agitator catches the lint as if flows through the screen. If the screen is clogged, not only will lint filtering be hindered, but also water circulation effectiveness will be hindered, this flow through style agitator was designed not just to filter the water but increase water circulation making washing performance better. I have a slightly newer version of this machine, I love it but I'm currently having a problem with it dumping grease on my clothing. My Mother has an even older but similar machine that is 39 years old, it was her Mother's, it is still going just fine. We did notice the belts were slipping and making a thumping noise and I could stop the agitator with my hand, if you can do this, get a new set of belts, they are easy to change and make the machine perform like new. They should be somewhat loose. Also you need to use the genuine belts, not some from auto parts stores. The genuine ones are made of a special material that is designed to slip at the beginning of the spin cycle. Could you sent a close up picture of the control panel? I'm curious about what the right row of buttons says and are for?
Enjoy this machine, this is one of the best and most reliable washers ever made on the planet, I kid you not. They are easy to fix if ever needed too, though some parts are beginning to be phased out as Whirlpool bought Maytag in 2005 and phased out this mechanical design in 2006 when they closed down the Maytag Newton Iowa factory where these machines were produced.
Hello from next door!
I'm in Prior Lake. What you have is not an "apartment sized washer" it is a full sized machine. Any machine this old going into regular service should be thoroughly gone through by a qualified service tech. I will Email you info on a repairman in our area who is a Maytag genius. How nice to have a "close" AW neighbor, welcome.
Nick Strand, WK78
Maytag Standard capacity
It's a darn good sized washer, closer to large than anywhere near apartment sized. and it's dependable, rinses well, runs for years with minor repairs. and it's 2 speeds and has a softener dispenser. Keep it, you'll be impressed.
What it won't do is king sized bed comforters, true, few machines can. It'll tackle darn near anything else you can think of.
My 510 is a Fabric-Matic like this one and its 1 speed with a Delicate soak/agitate at regular speed. Doesnt matter to me as I dont have "delicate" clothes. If it was a 2 speed, it would say it right by the Maytag logo on the panel. Mine is an extra large capacity and it does a king size comforter just fine. You ought to see the lint filter afterwards as my dog sheds like crazy.
Maytag Standard Capacity Washer
This is a 16 gallon tub machine, it is good for around 8-10 pounds of cotton laundry, 12 pounds is really pushing it.
Any modern US Front Load washer will easily wash twice as much laundry per load including many current top load machines.
It is a good machine for washing normal loads that do not have many large items in them, but it is not a great washer for washing delicate items in as the agitator and tub design cause a lot of clothing wear on clothing and can actually immediately damage delicate items.
John L.
This washer would apparently be smaller capacity than what is common today, which might be a negative cited by detractors. But I personally had little trouble when I was able to use a small capacity late 60s Kenmore. It was easily big enough to handle my day to day laundry. It helped that I tended to aggressively sort laundry, of course. I sometimes cynically think large capacity washers of today are appealing to many buyers just because they see the big drum, and think: "I can stuff ALL my week's laundry in and get it done at once!!!!"
I honestly miss that Kenmore--neither of the washers I've used since (both of which had bigger capacity) have been as satisfactory.
I'd rate this machine for:
18 Hanes XL Pocket T-shrts
or
4 pair of Wrangler jeans 36 X 34.
These machines wash well, the rinse well, they extract well, and generally run around 30 years between overhauls. I'd call it a winner!
As with any traditional U.S top-loader, delicate items like silk long-johns or bras should be placed in a mesh laundry bag before washing.
Nice machine, and welcome to the site. Unwritten rule around here that one must post a photo of the machine interior if you are going to post photos.
