Nuclear power is a difficult matter to discuss
Even including all radiation related accidents, it is a matter of fact that the mortality rate per unit of energy of nuclear is among one of the lowest.
Per kWh, it is relatively green even with the fuel cycle emissions included.
Nuclear power plants are some of the most reliable machines ever built.
Then, in theory, we can make even current pressurised water reactor tech much less problematic.
If you were to do things like fuel recycling, separation etc., you could get a years high level nuclear waste for one power plant into the single metric ton range.
Which sounds like a lot, but given that that is about a percent of the actual core material, and given how much energy you get from that, that is minute.
But, nuclear power is facing a lot of issues.
There is currently one single final storage facility for high level nuclear waste ob the entire planet.
And we need like at least ten times as many.
There has been no meaningful research into nuclear fuel recycling.
The big fear is nuclear proliferation, the uncontrolled spread of technology needed to create nuclear weapons.
Which fuel recycling very much is.
But without it, instead of splitting off the ton of stuff that is REALLY nasty and storing that in those facilities we have to store ALL of the nuclear fuel that ever is used in any nuclear power plant as "deadly in minutes for about a thousand years".
That multiplies the final storage situation with a hundred.
So we either need significantly more final storage sites - of which we have, as said, one - OR we need a few of these storage sites and a way more stable political climate.
And then, the thing I know most about probably, the engineering side of things.
You design a machine for a certain lifetime. You usually design it with a certain buffer to that design lifetime.
But almost all nuclear power plants online right now are very much at the end of their lifetime.
And even though the designs are out there for new ones - we haven't really build many in the past few decades.
It's a long and expensive process to even get started on that project, and even if you manage to build it, it will be INCREDIBLY expensive and might come online in a decade?
Nuclear power could be a reasonably safe stop gap solution for the next 40 years.
If people would be less NIMBI-ish.
If governments would try to not show of in self interest and actually care about educating their population and giving them the best -not themselves.
Then we would have to get a lot of projects up and going very quickly, but can under no circumstances drop the standards on any of them, cause, you know, Chernobyl, Fukushima etc.
And maybe have a solution online in 10 years - and would have to work on its replacement right away.
Saying in total:
That could have been a very good solution, in a better timeline than this one, started a decade ago.
In this timeline, it is very unlikely it will make any sense and get anywhere and that we are probably better off just going with the proper solution right away and skipping that stop gap solution.
