ian_p61
Hi all.
I recently got an asko t760 tumble dryer but there seems to be some trouble?
The machine turns on the screen lights up and you can select a cycle but the dry does not turn, all you can hear is a hum. Sometimes when you open the door then shut it and press start the drum will start turning and the cycle will finish?? But my times just it will hum and will over heat and switch off?
Thanks
All
Thanks
All
