attention maytag experts - need advide
stopmeister72
Dec 29, 2006
154
Irving, TX
Have a Lat9206BAE washer (Dependable Care) that the brake has gone out in. Tub indexes a little clockwise when washing and now there is a loud bang and comes to an immediate halt after spinning. While washing, I was holding- then turned the transmission, the brake released and it started spinning while agitating. Brake assemply is only $74.01. Wondering if anyone can give me advise on installing it before I tear into it? Looks like it screws in from the bottom. Anybody every worked on these before? Any other parts I would need to order when replacing the whole assembly? Any info is appreciated.
thanks,
John
[email protected]
Hi John:
No, just undo the belts, pulley and lock screw holding the old brake on. It will require a brake tool most likely to get it off. I have one. You just start turning counter clockwise for about 10 turns and it should be off. You may have to pull it to release it from the shaft.
Let me know how you fare.
Steve
thanks
Thanks for the info. That sounds easy enough. Should be picking up the parts monday and either starting it monday night or tuesday. Will try and remember to take my camera.
What does the brake tool look like?
Thanks,
John
