Audio Conversion Device
I think you'd get much better quality if you just plugged the output of your amoplifier into the input of your sound card.
But for those who are technically challenged it DOES seem like a good idea. I had no idea there was something like this out there.
why perpetuate the misery
Unless you use the most accurate equipment available to transfer your vinyl, you will be able to determine that the quality is not what you've come to expect in the digital age.
Those cheap turntables do not reveal the true beauty of good vinyl.
It's a good idea, but there should be a range of turntable qualities and prices. That one is just plain cheap, and is sure to sound that way. The stand alone usb pre-amp is probably a better bet.
I use the line out from my receiver and have for years - since the beginning of my using the computer at all, actually.
My secret weapon for transferring amazing sounding vinyl is a tool that allows me to determine the absolute center of the playback matrix and align it perfectly to the spindle - which eliminates Wow. The music does not go sharp and flat continually, but seems to just 'stand still'.
These days I also use a Shure V-15 type Five pick-up, which, by itself, cost more than twice what that whole turntable setup costs, but the superiority is clearly apparent.
Bob
Line out to pc
Almost every pc has a line-in jack on it. All you need is a cable.
Those usb turntables are plastic and cheap. Nothing like the older tt's made of heavy wood and metal.
neat idea, but that turntable doesn't look like it's of all that good of quality. My recommendation is to find a nice used turntable at a yard sale or a second hand stereo shop and use that instead. It does not have any counterbalancing on the tone arm, or any speed / servo control. If you already have a turntable in your stereo, then you are in pretty good shape.
You could also purchase a good quality brand new turntable from a music shop like Sam Ash or Guitar center. NewMark and Technics are the two top-dogs in the turntable industry. Make sure what you use has a good cartridge. Shure and Audio-Technica are my favorites, but there's also Stanton too. The cartridge on that ion turntable looks to be of very poor quality...and that's the most important piece when it comes to getting good quality recordings. Many semi-pro and pro grade turntables come with good cartridge, but make sure what you pick has a standard mount so you can upgrade it in the future if you want to (having a standard mount almost always guarantees a reasonable quality cartridge anyways!). One thing you may also want to look for is an RIAA pre-amp. This will allow you to input directly into any line in on a computer or stereo system. Without this, you will need a pre-amp, or a device with it built in.
Now, once you have a good quality turntable, there are two ways you can go about getting the sound into your computer. If you have a desktop computer YOU ARE ALREADY SET!!! Most desktop computers have a line in ready and waiting for you to plug any line level audio source into. Just go to radio shack, buy a "Y" cable that goes from RCA to mini-plug. Take this cable and plug it into a "tape out" socket on the back of your stereo, and plug the mini plug into the line in on your computer. Next, you will need a recording software. The one I prefer is called "Audacity" and it's an open source program that will make WAV's, MP3's and other audio formats too. It's a very powerful tool that will also allow you to edit and break up the tracks into individual files and such.
Now, if you've got a laptop, or any other PC without a good line in socket, you will need an audio converter box. One of these can be had at any computer or stereo shop for about $50. Again, run a cable between the "record out" on your stereo to your audio converter box and you're set. Now, sometimes you can find audio converter boxes that have the required RIAA pre-amplification built in like this:
http://www.retrothing.com/2005/11/art_usb_micropr.html
You may be interested in this Stanton turntable. It's of better quality, and will give you a bit better fidelity, be less harsh to your records, and is built better. The beauty of this one too is if you currently don't have a turntable for your stereo, this one has an RIAA pre-amp'ed output that you can run directly into it, and use it as a regular turntable when you're not ripping audio files.
http://reviews.cnet.com/turntables/stanton-t-90-usb/4505-7860_7-32417457.html
This is Good to Know...
Spend the $169 or more for convenient, poor-quality MP3's or else [to produce the best sounding vinyl to MP3 converts] invest up to hundreds more in high-quality audio vinyl equipment (new or good used). Thanks for your feedback.--Laundry Shark
That Stanton USB TT looks VERY appealing to me as I don't have a receiver with phono inputs and I'm the record collector of the house.
Naahhhh... I'll stick with my 1968 Magnavox.
I will stick with what I have-Rega TT connected to my Onkyo receiver-just play them-too much work to record to MP3-and I don't have a MP3 player.The other record player I have is an older surplus Army Signal Corps record player-PA-I hooked it to an Altec speaker-and it sounds much better than the original speajers that came with it-and it has a TUBE amp!Was built in 1956-mono but kinda neat.There is a similar machine pictured on Mash.
