Avocado Maytag KA606 / KDG606 Parts Machine Pair
lowefficiency
Jul 5, 2016
947
Iowa
A while back I came across a posting on Craigslist that caught my eye... I don't need any more projects, but classic Maytags have been thin on the ground since the pandemic, so this posting stood out. I checked again last week - and still there at three weeks since the original posting, I figured their days were numbered before they got sent to scrap, so I scooped them up. Turns out I was the first person who had even inquired about them.
The story as I recall - these might be second-owner machines? The washer was used up until recently, when it started putting oil spots on clothes, so I suspect the agitator shaft seal or shaft/bushing is shot. The gas dryer hadn't been used in some time - I didn't catch how long. Both are complete, but in poor condition in their own ways, so I'm not 100% sure what I'll do with them yet. But I needed a two-speed motor for my A408/A806 conversion, and the rest basically came along for free. If nothing else, it'll be great to have some spares of some unobtainable parts (carbon brush assemblies, the solenoid/chime mechanism, etc).
Looks just like the Maytag A606 and DG606 I picked up back in 2019. The Maytag A606 worked fine but the dryer however needed quite a bit of work to get it up and going again since the clips that held the motor down snapped from corrosion and I presume that’s why it was taken out of service along with it’s companion A606 washer. Pretty much had to do quite a bit to get it up and going again and not long after I got it back together the electronic dry control wasn’t working and that’s when I decided to put a 306 timer in and haven’t had any issues with it since and I think you might remember that debacle from 2019. So far the only repair I needed to make to it was replace the cycling thermostat since the high limit thermostat kept on kicking the burner off and that’s the only repair I’ve had to make to it so far in the 3 years it’s been a 306 dryer.
A look at the consoles...
The blue shading is gone over most of the panels, and there is damage to the white paint too. I'm not sure what would have caused the damage and shading in this pattern - perhaps something was taped or draped over the top for a long time?
I was also surprised at how different the color shades were between the porcelain and the paint. Is this an age effect, or were they always like this?
I believe the paint difference was a defect due to time. I have a 1969 KA806 where the paint on front and sides of cabinet almost appears gray compared to the avocado porcelain top.
On the dryer - inside the drum is clean. The white plastic of the lint filter assembly is distinctly yellowed - I don't know if being a gas unit accelerates this, but it's significantly worse than our DE806.
On that same point, ALL of the white plastics of these machines are more yellowed than any of my other machines. Buttons, dials, etc. So perhaps its just because they are older, or had more UV exposure... I might try some retrobright experiments on them and see what happens.
The rear shows upward rising rust from the air intakes, I presume this is/was the escape path for fumes from the standing pilot?
The dryer has an "HH" serial number, which dates it to April 1969 - one year and two months prior to the washer.
Under the console cover on the dryer, things take a turn. I've never seen it before in person, having only had electric dryers, but I presume this is what you folks have been describing - the long-term corrosion effects of a standing pilot light. Almost everything metal is lightly rusted.
The main selector switch was frozen - I was able to get it to move with some force - but it had been stuck in that position for some time. The detent mechanism on the dial seems to be missing - the knob can be turned to a setting and pushed, but as soon as you let go it just snaps back to one position instead of staying where you put it? That's odd to me, because I don't recall our DE806 having a spring that rotates the knob...
The bell / switch solenoid was also locked in place. I was able to free that up too, but it's clear that this hasn't been used in a while, and would need to be fully rebuilt before it could be used/trusted.
Sean, this is probably what your electronic control looked like? I'd be shocked if this was making good electrical contact. I do think it could be revived - with new connectors and careful cleaning of the PCB. But I'll learn more when I take it further apart.
Thanks. I wonder if there is an environmental (perhaps UV exposure) component of it? Or maybe they improved the paint formulation over time? I've seen others that still look great... such as this example:
"For Sale - Avocado Green Maytag Washer and Dryer"
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?16127
The paint color (or condition) on these machines obviously wasn't a factor for me, but like I said, I was surprised how far apart they were.
Have you thought of selling off the parts on ebay?
There are people doing that and I've done it a few times.
I recently took an electrolux vacuum I got for $7 and made over $200 by selling it off in parts.
Different collectors need different parts.
Most of this washer will break down into parts that can be readily shipped via UPS and the like.
Reply #8
Mine was in pretty much the same condition when I got it home back in 2019. As soon as I got it back together with a new carbon brush installed, it literally only worked 3 times when I tested it on damp dry setting and after that it just stopped working all together. Spent hours doing everything I could to get it to work, even tried soldering the wires to the board and that didn’t really help either and after that is when I decided to put a 306 timer in. There was some upfront effort but had payed off since I haven’t had any issues with it in the 3 years it’s been converted to a DG306. That’s another reason why I am going about putting a customized Maytag dryer to go with my A806 I picked up earlier this summer since I didn’t feel like putting up with the pesky electronic dry control and it works great when it’s working but is a rail pain when it decides to stop working properly or at all.
I hadn't before, but these might push me to it! The large parts (cabinets, etc) are the hard part of course... Otherwise, how bad are the fees for small value sales on eBay?[this post was last edited: 11/7/2022-18:11]
Ebay fees aren't the problem and pretty damn reasonable considering you're getting access to the entire US market and beyond.
The shitty part is Ebay now wants a SSN and bank account number.
Also, sales over $600 will generate a 1099 sent to you and IRS.
I don’t know if you have a gas hookup in your home here’s one thing you could do if you wanted to get the electric dry control, you could simply use that Maytag DG606 you picked up to air dry certain fabrics like shirts with vinyl decals or certain types of delicates around the house. That’s what I did with my Maytag DG810 when I acquired it back in 2016 since I didn’t have a gas hookup in the garage and surprisingly got everything dried despite only air drying.
Today was my lucky day - I got a call back from the seller, and he had found a few more parts for me. Included is a complete control panel (A208 I believe?), and a couple used water valves, fill level controls, and used hoses.
The control panel is complete and in great shape, which now has me thinking about "upgrading" our A209... but I know they changed the shape of the top of the cabinet when they changed the control panel styles...
Ok, finally had some time to look into the washer...
The agitator was tough to get off, but with rope through the core, a heavy weight, and a lot of yanking, it came free.
Under the agitator was... this.... So I'll have to do some cleaning to get to the tub nut. The agitator shaft itself doesn't look too bad though.
The base of the machine looks fine. Not perfect, but infinitely better than the one on our A408, so I'll keep this one and clean it up. The prior owner mentioned replacing the damper pads at one point in the past. The pump is still of the older split type.
Holes In The Outer Tub
Hi Dave, That washer had water sitting in it for at least a few years,  I would look for a better machine, maybe use the green cabinet on a better machine if you like this model
Its a shame I still see often pretty minty DC and even center dial MTs on the scrap pile every month around here but no one comes and gets them.
Sometimes I pull them apart for parts but I already have more dampers and transmissions etc than I will ever need.
I do grab the consoles with wiring harnesses and use them to extend the life of some of our older customers machines when they have a timer failure because timers for DC MTs are getting expensive and scarce, but most DC MTs are being trashed with ad transmissions and badly worn dampers where they are metal to metal.
Thanks John. I might have mislead with my wording - "so I'll keep this one and clean it up" was in reference to the base plate in particular, not the machine as a whole. I've taken the machine further apart, and it's definitely on the wrong side of the "too far gone / not worth rebuilding" equation. So much so that it's not even a particularly good parts donor. But I'll save what I can.
Have you considered putting some of those spare transmissions up on eBay? Even as-is, they aren't really something that is available on the marketplace...
Continuing along... The top of the tub cover looked good... but the bottom, not so much. Quite a bit of rust around the seal line. Some of the discoloration on the underside is rusty / hard water stains, same as the inner tub...
The stem also refused to come off the normal way. The setscrew, once I found it, was stuck tight enough that the hex end rounded out before it came loose, so I drilled it out. I ended up using a Dremel to score it, then the cold chisel again to smash pieces of it off until it finally came free.
Crusty Outer Tub
Holy cow! That outer tub is absolutely nasty. I thought the inside of mine was fairly bad but it’s nothing compared to the amount of rust and gunk build up inside this machine. Here’s hoping my machines never end up even close to as bad as this one.
On to the bottom. A ring of greasy dust around the inner perimeter, and the feet need replacement, but otherwise in good shape down here. The belt has been in one position for a while judging by the shape.
