Beko Heat Pump Dryer
AEG
Hi Brendon, can you take another picture further back or wider , I cant work out what the carrier looks like, so yours has the door filter, then a another fine filter and then the black sponge pad?
Is it me or does there appear to be more FINE POWDER RESIDUE with the heat pump dryers, or does a normal condenser somehow keep it in the water etc??
Or does the heat pump do such a good job of getting rid of all the moisture that its seperating the fine powder from the water??
Thinking about it even when the loads are dry in a condenser, the workings of the dryer are still moist or wet whereas the Heat Pump dryers appear not to be so!!
Your New Dryer
Nice looking machine AL, I wish you well and look forward to an update on how you find it when you have been using it for a while, I bet you’ll find you use a lot of the programs later
Sorry to rekindle an old thread!
Ive had the dryer now nearlly a year. Warranty nearly up but a question for you. When your drying bedding consting of 4 pillow cases, fitted sheet and duvet cover I find this dryer tangles them all up into a ball... Thats also ensuring that the buttons to the duvet are fastened so things don't go inside, they still roll into a big solid ball.
I expect the issue is because its only got 2 drum paddles or the fact the reverse tumble only lasts literally 5 seconds before going forward again.
Have you had this issue?
