Bendix 7168
sesteve
Jun 22, 2012
795
London, UK
Has anyone got any experience of changing the door boot on one of these? I picked the machine up a couple of weeks ago and it seems to have an unusual fastening for the boot onto the tub using a split pin. I'm not sure how to tighten the band up if I take it off by removing the pin.
Here's a picture of the pin at the top of the seal. Can't do the multiple photos on the iPad so will add them separately
The machine has suffered some damage as one of the top suspension springs had come off by the soap dispenser and this had damaged the dispenser itself. I found a replacement dispenser only to be told it was out of stock and they would let me know when it was back in. Well the new one arrived today. It's a bit different so will have to do some modifications to fit the top but it's better than trying to patch up the old one
I might need to get a new pump for it but apart from that it seems to be in good working order so hopefully the door boot isn't too hard to do
S:)
Boot clamp
Hi, Congratulations.It looks to be in good shape,one of the quietest washers of its time.The boot clamp is quite easy to undo/do up.The strap at one end of the clamp passes through the slot in the pin ,so by turning the pin either unwinds,loosening the clamp or winds it up tightening the clamp.Just put a small screwdriver through the eye of the pin to use as a key to turn it.Hope this helps ,kind regards Nige.
Canned meat
Hi Nige
Thanks for the advice - just like opening a tin of corned beef lol. Good job I didn't remove the pin then. You can see a serated edge on the top of the band itself by the pin but it's not obvious that it turns. Will give it ago and report back. Am excited to get this going as they are really well built and it should be quiet - the pump is quite noisy but it might be better when there is water in it as I took it apart and it was spotless.
Mike - I wonder if this method is because this machine has a concrete weight attached so access for a screwdriver is difficult? The Haynes guide doesn't mention this type of fixing but does say that some of the machines with the front weights require them to be removed to change the seal. The pin must be a method to avoid this I guess.
S :)
I thought that a weird comment myself (#8).
Seeing everything though the money lens is a sure way to drain the fun out of life imo.
Or maybe it was just some humor...
Hard tell in' not know in'.
Love the repair threads.
Bendix
Oh, interesting clamp thread, must check later models to see if they carried it on!! Steve can you post a full top pic to see how far the concrete weight protrudes over the top of the vitreous enamel tub compared to the 7147 earlier model - wonder if it was bigger to do with the faster spin?
Here is the 7147 from top. ps, just noticed the size of those capacitors!!
Hi Steve
great to see you get stuck into another restoration, yes just like a corned beef tin. Interesting this is the clamping method used for the boot on the bendix LT, so maybe a bit of mix and match over the years.
Also Steve if you need a boot I may well have a spare.
Mathew
Boot / Door seals
Please ask Rob if anyone needs a boot off an old model machine I took 4/5 black bag fulls along with numerous other spares.
Austin
Hi Mike
I've taken a few more pics which show the top weight. There is also one on the front of the tub. The soap dispenser is removed ready to be replaced. I've never seen plastic hoses from the valves to the dispenser
Hi Mathew.
I couldn't resist but it is about time I started restoring these properly instead of having so many half working machines. I might be in trouble with the door boot I've purchased. I read somewhere that the number on the ratings plate would translate as February 1984 .....
In which case this won't fit grrrr.
I remember about you saying about those bin bags Austin. I might have to follow that up
S :)
Steve Yes I have the seals Austin mentions - I cant see why the one you have bought wouldnt fit as round door machines had been in production since 1982 and surely their all the same.
Be worth checking against the old one to make sure its right - maybe even fit it and see how it goes so you have not wasted your money.
Interesting to see the earlier 1000 machine with an enamel tub as our later 1985 version has a stainless steel outer tub, we'd assumed the faster spin TOL machines like these got the stainless tubs for whatever reasons.
I'l have a nosey thru the seals at the weekend and see what I can find :D
Hi Rob
Yes I'll see if it does fit when I get a bit of time. Perhaps the stainless steel tubs came in after September 84 hence the note on the seal. The enamel tub might have a different lip but I'll soon find out. I'll report back when I do it.
Cheers
S :)
