Bendix Boot Mechanics 101
jetcone
May 2, 2001
7,678
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
Okay I have been rooting around in Roberts' Rubber Room ( don't tell him!)
and found "in Stock" all the Bendix boots!
I am posting pix below so everyone can understand how these boots interchange because it also shows that the boots from Europe are the right size for the Gyromatics and the Duomatics.
All three boots are presented by the Maytag repaiman below adn Eddy (Eddy1210).
The first photo shows all three boots together and you can see they are the same diameter but have different profiles.
With some extra closed cell foam you would be able to retro fit most machines witht he new boots.
FIrst Bendix Boot Ever
This is the 12920 which was the boot for the first two models of the Gyromatic which as you all know was the first non bolt down Bendix machine.
Eddy & I just discovered looking in Doctrine that the two boots he is holding in the last post are interchangable from the factory because BOTH parts numbers 9118-23 & 18121 are listed under "Quick Reference" for the same boot application!
Wowwww!!!....Spooookeyyy!!!!
Hi Jon
Glad to see (In Person) that they fit, looks like I`ll be needing to order when I get back, my repair man will be pleased..
For all members wishing to order please check with Jon and then he will send me numbers...
Mike
"This is really spookey being round the corner from you at Scotts and typing this".....Yaaaayyyyy for Convention 2005.
