Anyone have any tips or tricks for extracting a fragile aluminum impeller off the shaft of a Bendix drive unit with no clearance to get a gear puller on it? Only thing I can think of is take the whole drive out, loosen the cap on the back of the motor, and try to push the impeller off the end of the shaft with the whole back of the motor. I did get the set screw out and tried a round 1 with a torch and vise grip pliers on the hub. Zero movement.
Somehow on running my machine, the screws behind the pump impeller backed out alot and the aluminum pump housing now has quite a bit of wobble on the back end of the drive motor. What started as a little water leak has become too large of a leak to ignore.
