3beltwesty
- Joined
- Nov 29, 2010
- Messages
- 1,057
RE; So . . . what is screwed, and what is welded drum?
The part that rotates that holds ones clothes is often called the "basket" or "washing machine basket" in Engineering lingo.
To start with the 201 series Stainless Steel strip is just a polished thin sheet off a giant roll.
It is cut/punched out in a long rectangle, the long side is the circumference of the basket. It is rolled/bent into its tube shape and either screwed, crimped, welded together or a combo of several methods.
As the spin/extract speed gets higher in newer designs, the "joint/seam" becomes more stressed. Thus a crappy poor joint maybe fine with an ancient 500 rpm extract, but dicey at 1200 rpm. The stress goes up as the square of the rpm. A basket at 1500 rpm has 9 times the stress on the "joint/seam" as one at 500 rpm.
It is made like a "soup" can; that some have a "seam/joint"
This joint is what failed.
