maytaga806
Hello all I just wanted to get in here to ask something that I’ve been constantly confused over for the last many months. As some of you know I got a powerclean dishwasher last year and I was told since I had the direct feed I can interchange the wash pump outlet and install a tower and correct spray arm with the black nozzle after removing the old stuff, well when I did this you’d think the upper spray arm would work as the tower system, since it has all the same parts.
I know I got into this topic a few months ago but cannot find the thread of replies, but I put my camera in to see if it was working properly and the upper arm had very low pressure and wasn’t jetting much water out, the jet streams weren’t even high enough to reach any of the dishes on the top rack. I checked the alignment of the tower to the spray arm, everything is directly in the middle of the racks as they should be to meet up with the black rubber nozzle. It makes no sense to me whatsoever, the upper arm is not clogged it’s been fully cleaned, the tower is missing just two out of 4 of the clips to snatch onto the rack, so I don’t know and that’s where some of you come in. I will attach the video here, I took it all oht and redid it over and over and everything was correct the only piece I don’t have is the small ring for the black rubber nozzle but I don’t think that makes any difference at all.
Do the direct feed powercleans have a different impeller or something I’m unaware of? Do I not have the right wash outlet? just doesn’t make any sense to me at all and I’d really appreciate input and advice just because I can’t make any sense of it and it at the time was just a fun experiment nothing permanent and it’s left me baffled ever since. This model being a 2005 is an energy star direct feed built, could it be that it just doesn’t use as much water as the tower models? Did the tower models need a higher water level to create enough pressure going to the upper arm and the direct feed models didn’t need as much water as the tower system? Cause the water level on mine fills slightly below the element but has full on pressure for the upper system as I have recorded that as well and works just as it should and I was shocked to actually see how powerful my upper arms pressure was on my direct feed.
