Blackstone 350 Rebuilding
blackstone
Jan 27, 2006
837
Springfield, Massachusetts
I'm currently rebuilding a Blackstone model 350 for a lucky member, and took some photos yesterday. I'm not doing a complete restoration, just putting together a working machine, so I can move it out of the store. First step was removing the transmission from a 250, and putting it into a 350 cabinet.
Groan!
Picture of the transmission removed from the 250, ready to drop into (figurately speaking, of course) the 350 cabinet. This sucker is just about at the limit of what I can lift and carefully drop down. Not much to reconnect the transmission once into the cabinet--only the three nuts to bolt it in place (not that it has anywhere to go to); the cable connecting to the water valve; the linkage to the control knob; and the electrical connection. Next step will be sliding the outer tub into the cabinet and connecting the hoses.
Very interesting Fred, thanks for sharing this adventure with us. I will look forward to more pictures as you continue with the restoration.
The transmission that was in the 350 did not work because apparently the mechanical timer inside the transmission was not advancing. Another 350 had a broken connecting rod inside the transmission. The quickest fix was to swap the transmissions, and save the rebuildings for a later date, when I have more time.
I had two 250s and two 350s in the store, only one of which had a working transmission. One of the 350 transmission had a broken connecting rod; the other had a mechanical timer that was not advancing. Easier to swap the transmissions and save the transmission repair for some other time.
This picture is named "Feet_on_Disk" because that's exactly what it is. The disk has to be seated as far down as possible, and the best way to do it is to stand on the disk while you tighten the set screw. Try doing this in a plastic tub Whirlpool.
View of the bottom of the stainless steel inner tub. Well, the bottom is actually cast iron. Die cast bottom of post sits on disk; when tub gets lifted up, water gravity drains through the holes in the bottom, before spinning removes rest of water.
Inside view of tub after set into machine. This is the second-most strenuous part of the job, since the tub weighs 70 lbs. Best done with two people, but I didn't have anyone around to help. In other words, make sure what you do prior to this step is right, or else you will be lifting the tub out again. Still a nice shiny washing surface after 50 years.
Close up view of brass water valve and water deflector. There is an extension piece on the outer tub to collect water drippings from here, but I wrap something around this opening to help guide the water and prevent it from spilling inside the cabinet. The brass pipe is bent for proper adjustment.
