frankpc
Just installed a new 5-port valve in my LG Top loader washer that is 6 years old. Valve works properly except for excessive water flow to the bleach dispenser. When the valve opens to supply water to the bleach dispenser, the bleach and water mixture flows down out of the dispenser into a shallow reservoir on the side of the tank at the top. The reservoir can't drain into the tank fast enough so it overflows which allows water to flow around the top of the tank and into an open drain on the rear side of the tank. That water drains onto the floor below the washer.
It seems the valve for the 'bleach water' should have been restricted. Never had this problem with the original valve.
Anyone else experience this problem?
