ozzie908
Similar problem
My Miele dishwasher drains into the waste disposer it does remove grease etc but a bad design in the plumbing under my sink is, there is no way to clean out the pipe that goes to the main drain, We have to remove all the pipes and use a pressure pump to unblock it now the problem I have had is the water pumped from the DW never goes back into it as it has a anti syphon which believe it or not is just a large stainless steel ball sat in a housing that drops when the pump stops thus preventing back flow. A simple but effective device I wish the plumbers and electricians had thought about my sink though as we have a boiling water tap with a trap that allows unused water to drain away if we have a blockage every thing flows out of this little trap and guess what's been fitted directly under it ????? Yes the power points for the DW etc so off goes the power so not only is it wet its now dark.... All good fun lol
