Looking for GE WH23X42 pump
jdm
Sep 3, 2025
4
I need a pump for a GE washer that has started to leak a lot. The part number is WH23X42, and it is a 4-port pump with a metal cap on the top. I have been having trouble finding one that is reasonably priced. Any sources for these would be appreciated!
Looking at the longer term, can this pump be rebuilt? If anyone has done so, I would be interested in what replacement parts such as seals were used and where they could be obtained.
Thanks for any information!
Not sure what pump you’re looking for. Do you have a picture of it? There are no GE pumps that have a metal cap on the top that I’ve seen.
What’s the model number of the machine or a picture or how old is the machine that you need to pump for?
It appears to be a FilterFlo 4-port pump. The referenced metal cap presumably is the pulley to which the flex coupler attaches.
GEAppliances.com Pump WH23X42
Signed: Goofy Glenn
    29.9 KB
The model number is WWA8858MALWH, serial number LF195336G. I think the WH at the end of the model number is for white machine color. The picture by DADoES is correct, and yes, the metal cap is where the flexible coupling connects.
Can someone explain why this pump has 4 ports? There is one source for the water (the tub) and one destination (the drain hose), which would only need 2 ports to connect. One thing I had looked at a bit was getting a combination motor/pump like https://www.ebay.com/itm/286693900470 as a replacement, but aside from the work involved in retrofitting, these pumps quite reasonably have only 2 ports.
