Bosch Nexxt 700
tnmike
May 16, 2007
111
Knoxville, Tennessee
Hello everyone. I have a problem with my Bosch. Occasionally when it is filling for auto load adjustment, the machine will keep on filling until the water level comes up on the window. If I stop the machine and restart, the fill stops and cycle continues. If I leave it alone..it will fill up far enough the pump will switch on and fill stop. It seemed to do it more with Cold wash but now will do it on warm and hot. Not every cycle has this problem. My partner LOVES Downy. If a little is good, a lot is GREAT! I thought maybe it is build up in the machine..so did a Tide Washer Cleaner cycle. Next load after did not keep on filling, but we will see. Any suggestions??
If you run mostly cold washes, probably you were right about buildup and the cleaner has done its job solving your problem.
By stopping the machine you allowed the pressure switch to sense the signal ( signal on late because of buildup in the pipe that slowered airflow)
Now and then run your whites with very hot water. Run sanitary cicle if your W has internal heater. Otherwise raise your heater temp and purge pipes before starting the W.
Boilwashes are only on euro Nexxt ... if you had 220 V ;-)))))
