Brought these stragglers home
Oh very cool!  If that dryer happens to still have its wiring diagram, can I trouble you for a picture?  I've got a 51 that looks like it got pulled from the bottom of a lake, in need of a full restoration needless to say, but is missing the wiring diagram.
Kenmore Bolt-Down Automatic
Wow, I never saw one with a blue outer tub, otherwise it looks just like my 1947 KM BD, there were many different versions of these BD automatics even though they were only built for 5-6 years.
I have not gotten around to restoring this machine yet, I have all the needed parts for these cool early KMs.
All the dryer will need is a good cleaning, and oiling of all the bearings and such. This Kenmore dryer more than likely has the dual fan setup on it and I believe they kept that until 1953 or 1954 sometime.
70+/- years old.
Wow.
They look like all they need is a good wipe down and they'd be ready to go.  It's amazing that people hold onto this stuff all these years.
The second fan was to help with air flow on these older Whirlpool built dryers and interestingly enough the perforated drum back on these older Whirlpool built dryer is built out of a chicken wire type material and are more open per square inch compared to the late 50’s to 1965 Whirlpool dryers with the stamped perforated drum backs. Putting felt strips around the air inlet and exhaust might help but since the perforated drum back is much closer to the stationary bulkhead it won’t really matter.
Well
I think I might try to bring back this bolt down. It is in okay shape but will probably need everything. I like to clean them up a bit so it is a little more rewarding to work on them. This is the before shot
Here
is an effective agitator repair on the one that was in the machine. Maybe it is original? I don't know but I have another one I think I will use. That original one is a little too ugly now but I do kinda like it.
It sounds a little rough when I move the agitator so I am thinking it needs new bearings. I will try to get out that inner tub next to see what is going on.
A Vari-A-Flex will fit but I am not sure what the agitator shaft looks like but if it’s the older style with the metal drive block it won’t fit but if it has a newer transmission with the newer style of agitator shaft it will fit.
Kenmore Bolt Down Automatics
Yes to use any Polypropylene agitators the washer would need the 1964 and later agitator shaft, but it is highly likely that when this washer gets rebuilt one will not find a good pre-1964 shaft to use.
WP discontinued the old style shaft in 1964 and replaced it with the new shaft.
these
of course were really a pain to get off. They are held in with a pin through the whole knob which hasn't moved in 70 years, so one needs patience -- to tap a punch through and I had to carefully drill out about half of it.
Hi Brain, Very cool that you  are starting to restore this neat machine.
The one we have looks exactly like yours except yours has a blue outer tub, I wonder whether yours is older or newer than ours, I believe I have found that ours is 1947 or 1948, Have you found and dates on parts yet ?
Does yours have the Suds-Saver system still ?  Ours has an electric return pump which is a very early SS system.
Those  knobs were not meant to be removed easily, On ours I  removed the knobs with the shafts attached and my friend John Eichinger in St Paul MN restored the painted areas on the back of the knobs without removing them from the round steel shafts.
Keep us updated how it goes, I may have some parts for your machine.
Knobs
Thanks John I can see that that would have been a better way to get the knobs off, I was treating it like my 51 Kenmore which come off on top. I guess I just will figure it as honing my skills at taking stuff apart.
Does anyone know if the tub to pump hose on these early Kenmores can be replaced with the more modern one I am seeing online? or do I have to mock something up? thanks
You might have to use the pump grommet that’s used on all later belt drive washers along with a coin trap and that will alter it’s originality a little but if the parts are interchangeable it won’t be that big of a deal.
Paul
here is that wiring diagram. this machine is early and is different than my 1951 models. I did own one of these so I have some spare parts (like 1950 or so)
For instance there is a solenoid operated switch in front of the heat element that they eliminated. and a motor choke coil? that is separate (I think). this motor has three wires coming out of it, not four.
Dryer wiring diagram
Thank you very much for this Brian!  It seems to be the right one for my 51!  I had seen the 'choke coil' (aka a transformer for the germicidal lamp) but could not figure out why there were extra wires from the timer...  Some clever soul bypassed the 'solenoid switch' at some point in time.  Let's just hope the timer contacts haven't been cooked.
It's about time I tackled this dryer... maybe now I'll actually start!
So
I am going off of Robert's 57 renovation for some guidance and after pounding and heating I was about ready to give up and get my grinder with metal cutting blade but I noticed it had moved about 1/8 of an inch so I knew I could get it off. This gear puller came in handy after that
The question is
does this inner tub on this real old machine now just come off or is there something else I have to do? It seems pretty solid so I have just put some oil in there.
Notice that this drive block on the shaft has just one notch not like the gear-like configuration on the later models. It was a real bear to get off.
So is there some technique to get this inner tub out?
Disassembling An Old WP BD Automatic
To remove the metal agitator drive blocks heating with a propane torch makes them lift on and you should heat it to reinstall it as well.
To remove the wash basket you stand in the washer and rock your weight from side to side a few times and it will loosen and lift right out. [ I have done this more than 100 times ]
