Buying a new Toilet this weekend - Any advice?
Mineral buildup will cause sluggish flushing overtime, even with superior flushing vintage toilets. The trick it to pull the toilet and put it in a large plastic container. Pour straight muriatic acid in tank to bowl opening so it gets in the rim jets and keep pouring until the bowl is full and begins overflowing out the trap way to clean the trap way out (another area that's prone to being clogged with minerals and causes sluggish flushes). A good soak overnight melts it all away. Use baking soda to neutralize the muriatic acid when finished.
I've occasionally used CLR on the toilet.
I'd drain the bowl first, so the lower bowl jet is clear of water.
Then I pour some down through the tank's overflow tube so it runs out of the rim jets, some comes out of the bowl jet, and let it sit for about 15 minutes.
It dissolves any calcium or lime buildup.
Then..... just flush!
Often times I get silly, humor-prone, friends know my twisted humor well.
And with the way the world is these days, I try to "lighten up" things in order to stay sane....
So... the title of this thread is:
"Buying a new Toilet this weekend - Any advice?"
And my tarnished brain said:
Sure, here's some advice!.... Go try out a couple in the store and see which one you like best!
:poop::poop:
Matt, My neighbor on SSI claims to be a conservative. We live more conservatively than they do, but we are not of their proclamation at all. Especially when we see so called law enforcers killing without just cause when a person could have been remanded without violence by disabling a vehicle, etc. You do not get to pick and choose small aspects of an ideology. Flush It down the Toilet!
