Cake - What am I doing wrong?
DADoES
May 21, 2001
15,785
TX, U.S. of A.
I've made Jeff's chocolate pound cake twice. Both times it came out of the pan like so. What's the trick I'm missing? This one is intended as a gift for a friend, but it doesn't look very nice. It cooled for several hours. Too much cooling? Not enough greasing (looked like plenty to me)?
Glenn--
1) Grease AND flour the baking pan. I use Crisco No-Stick Baking Spray with Pillsbury Flour (in a blue can in the aisle with all the other Pam-type non-stick cooking sprays). It makes the job very easy. But you can certainly grease and flour the traditional way.
2) Try removing the cake from the pan after 20 minutes of cooling. If the cake cools completely before you flip it out, it will want to stick to the pan.
cake
When baking cakes ALWAYS grease the tin well with butter and flour it afterwards before filling the cake-mixture in it. For very fine cakes (sponge-cakes) use flour for others use fine breadcrumbs or better semolina to coat the buttered tin-surface.
After baking leave the tin for about 5 minutes outside the oven on a wire-rack to set and make shrink the cake a bit, then turn tin onto a wire-rack which you lay on top of the tin first and turn them both over together to avoid a dropping of the cake onto the rack which can cause the cake to break like on your photo! At least lay a cold wet cloth on top of the tin. That will cool the tin immediatly and evoke a thin layer of condensed humidity between cake and tin-surface which loosens the cake. Lift tin carefully and slowly, shaking it a bit while lifting, and let the cake cool on the wire-rack completely for several hours!
If all that fails, the tin has a bad surface and probably will never bake satisfactorily. You should look for a new one then.
Ralf
I hate it when this happens!!
This happened to me once and it was because i didn't grease and flour the pan enough. I'm going to try the baking spray that frigilux mentioned.
Here's the stuff you're looking for. It works great. I've never prepared a baking pan the traditional way since trying it. Makes the process simple when using things like muffin pans or Bundt®-style pans.
I'd steer clear of Baker's Secret spray. Its spray pattern is uneven and it foams up like oven cleaner. I wrote all this in another post, but I must have forgotten to press the 'post' button because it didn't show up.
Thanks. The posted recipe instructs to grease the pan "liberally" but doesn't say to flour it. It also says to cool completely before removing the cake from the pan. Perhaps I can try once more before I run out of time for the gift-giving. I did make another cake last night that can be substituted (Gingerbread Cake).
I'd never do a 'grease only' preparation on a pan for a cake that gets tipped out of the pan. I even grease/flour muffin tins. Just a bit more insurance that nothing sticks. I'd also not cool a cake completely before removing it from the pan---barring a classic angel food, of course.
Glenn!!! NO FLOUR!!!!
Glenn,
I've never floured the pan for that cake, so I don't know what the result would be.
I have learned something though, that namely this cake will bake in MANY different pans with good results. Thats good to know.
I have always baked this in a regualr angel food type tube pan, first using the two-piece pan, and then later using a non-stick one piece pan.
I grease the pan with butter or margerine(using shortening changes the taste somewhat)
I probably use a couple of tablespoons of butter to grease the pan.
I can't remember off the top of my head what the recipie says, cool completely or for only 15 minutes. I can say I have had them break apart coming out of the pan, and what you've had too. I always serve this right side up, I like the look of the cracked, crusty top.
You could certainly use the cake pictured above, just flip it over and serve that side up.
I'll be making one this weekend for my neighbors Michelle & Lucas, they are total choco-holics!
We'll see what kind of luck I have...
Eugene is right
Crisco baking spray will Pillsbury flour is the best. I baked 12 bundt cakes last night and am on the next round this morning. Every cake fell right out of the pan very cleanly. The hint for cooling for 15-20 minutes works great.
I can't wait to try Jeff's cake!
VERRRRY good cake Jeff
Hey Jeff;
Made your cake this week...SUUUUPER rich! ! Guys at work were on it like a duck on a June Bug ! ! !
I used the 2 piece tube pan...left it cool completly,(sprayed pan w/ Meijer brand baking spray) went around cake w/ knife and flipped it out of pan, removed tube and served right side up, dusted w/ conf. sugar.
Thanks for the great recipe Jeff!!
Happy Holidays to all ! !
Al :)
I use a similar product like the Crisco with flour that is called Baker's Joy and believe me when you go to take the cake out of the pan it is a joy. Even worked great on a cast iron corn stick pan. Can't wait to try Jeff's cake myself.
I apologize in advance.
HMM I have never had any luck with a Bundt pan with or without flour.
Editor's Note:
Oh how times change! This one is BOUND to offend someone. Talk about politcally incorrect?
My great-aunt was part Polish and forwarded to me before she passed-on a gugelhopf (sp?) cake recipe (the aboslute BEST cake I have had to date!) that was her mother's. It calls for a "Turk's head mold" this was a printed recipe, published that way! That took me a while to figure out it meant a turban...or a Bundt pan. OY VEY!
Hi Terry. Bakers Joy and Pam with flour for baking are also very good too. However, one thing I noticed with the Crisco & Pam spray, is they seem to coat the pans more evenly. The spray is more like a fine mist. Whereas, the Bakers Joy of late, the nozzles seem to sputter & splatter. So I always ended up brushing the stuff around the cake pans anyway. Have you had that experience? Maybe I just got a bum can or two.
I've noticed that same sputtering and uneven spray with Baker's Joy - I'll have to try the Crisco version.
Do you hear that thumping sound? That's my grandmother banging on the lid of her grave at the thought of spending money on spray grease and flour! ;-)
Has anyone tried using the Wondra flour in the can? That's what we always used growing up, it's a coarser grain of flour - lots of uses, gravy, etc. but it makes cakes slip right out of their pans.
Never tried it
Those baking sprays... I do use PAM now and again for cooking though...
I'll have to try the wondra flour though and see how that does...
I share Toggle's experience: Never had much luck with a Bundt pan(or any kind of fancy cake pan) unless the goal would be to have the cake run out of the pan and all over the oven, stinking up the house and even on occasion filling it with smoke... then they are successful!
Snicker, we are slaves to convenience products
Greg, if I'm not in a hurry, I'll brush a regular cake pan with shortening and dust with flour. We have Wondra, so I'm going to try that next time! Thanks for that hint. Bundt pans with all their grooves & crevices can be tedious, so I always use baking spray. In fact the Nordicware folks strongly suggest this.....for best results! In other words, no cursing in the kitchen!
My Austrian born mother does what Ledersteiefel1 suggested; a well greased/buttered pan and very fine bread crumbs. However, the last time I peeked I saw a can of Pam Baking spray in her kitchen cabinet too. She must have had a coupon!
O.K. here is a thrifty recipe for cake pan coating from Duncan Hines that you can make & keep for up to 6 months at room temperature:
Combine 2 cups vegtable shortening and 1 cup all purpose flour with an electric mixer. Brush cake pans liberally. Cover with plastic wrap & store.
Has anyone baked Shortbread yet?
Leslie
Yes Leslie, I have had the same problem with Bakers Joy but always felt is was worth the problem as everything came out of the pan, including bundt pans perfectly. Next time I will give the Crisco brand a try. Terry
Sticky Issue
Your pan is cast aluminum and needs to be seasoned like a fry pan. Grease it with Criso (solids burn at a higher temp than liguid) and bake the empty pan at 250 for a couple hours. Don't scrub or soak the cake pan. Use salt and rub the pan to clean it. Then grease (solid) again and store. Frigulux is correct. Remove within the first hour. Try using an Angel Food pan instead of the Bundt. The cake is much easier to deal with that way.
Best dishes,Kelly
