That all depends...
I've restored some machines, mostly Maytag, that were in really rough shape, but I knew what the outcome would be, so it was worth the work. And I wanted to actually use the machine on a regular basis.
It's difficult to give an assessment with just a few photos, but if the machine appears to be in good shape mechanically (including the wringer gear box/frame and rolls) then it may well be worth the effort and expense. You could have the wringer's drain boards re-chromed, but I imagine that wouldn't be cheap.
Does it have a pump? If so, what's the condition?
Would you be doing the work yourself? And do you plan on using it once restored?
