Calling the Frigidaire experts out there - help with a Skinny Mini
revvinkevin
Jan 7, 2007
5,592
La-La Land
I am in possession of a friends Skinny Mini (Golittlesport's), the real one with the "Agi-Tub". The last time I used it I noticed the spin speed with a load of cloths in it is NOT the same as when empty, it's noticeably slower.
I assume it's just a friction thing of one roller against another which makes it spin, is that correct?
It was suggested that I try cleaning those "rollers" underneath. What should I clean them with? Do you have any suggestions?
Thank you much in advance!
Kevin
Clean the roller with lighter fluid. The belts are not used for spinning, altho' the mechanism will still look like it is agitating.
"Wow Skinni-Mini it's a giant for size! A washer that washes and a dryer that dries.Two single units for all your laundry care.Only 2 feet wide so it fits anywhere. Skinni-Mini, Skinni-Mini---fits almost anywhere!!!-----
-----Frigidaire bothers to build-in-more help!"
Just a little trivia from the 1970 commercial on TV.The Miss Universe Pagient was sponsored by FRIGIDAIRE and Buick(Wouldn't you really rather have a Buick today?)The next big sponsering wasn't until 1975 for different machines from F
PeterH770........
Lighter fluid? Why lighter fluid? Is there anything else I can use that is... oh... I don't know... less flammable?
So, OK then... lighter fluid it is.... but....
Are we talking about lighter fluid for lighting a BBQ or lighter fluid for refilling cigarette lighters?
(or perhaps another flavor I'm not thinking about??)
Thank you all for your help!
Kevin
Skinny Mini
My grandparents had one at their ranch and I remember that it was really good at cleaning clothes and the agitator and tub were one piece of molded plastic. Way cool!
Zippo Fluid
Kevin, go to your local tobacconist, pick up some Zippo lighter fluid and a Macanudo Portofino or Hampton Court cigar.
1) clean the rollers with a clean cloth dampened in the fluid.
2) after step one is accomplished, sit back and relax and enjoy the cigar, and your favorite Cognac and reflect on a job well done.
Dave
Recommended in the Frigidaire Tech-Talk repair books. Zippo is usually available in the tiny smoking product section of most grocery and drug stores.
If you are lucky, Chico and Harpo are available also, and if not, you may become Groucho.
got any pictures of the skinny? i would LOVE to see one inside! a video would be cool too! i havent seen one is years! would bring back alot of memories!
another Skinni Mini question
While we are at it, does anyone have a Tech-Talk that describes how to remove the control dial? We have a new timer for this unit, but can't figure out how to remove the knob. Duh!
