Calypso Number Two
Well, I picked up the Calypso from Craigslist today. It's in very nice shape, no terribly foul odors and after testing it does indeed have a bad pump. The lady had saved all the paperwork and even the styrofoam tub-block it came with new. I asked why she wasn't going to repair a washer that was this new and she confessed that she had been lusting after the LG Steam Washer and just needed the excuse to buy one. Quizzing her further, she also confessed that the LG didn't clean as well as the Calypso - she has three boys and thought the Calypso did a better job at stain removal and "flushing the grass and sand away" than the LG does. I'll pick up a new pump for it this week and get it running again - it will be a great machine to have in the garage for rags and other washing. I really liked the one I had several years ago and you certainly can't beat the price of this one!
Greg you said the machine was in good condition when we talked but boy that is unreal. It will be fun for you to have one again to play with .
Oh Wow!
That is in great shape!
Also looks very clean.
I love what she said about this washer compared to her LG. That is awesome!
I really think the Calypso is such a great machine when used correct.
The one you found is so clean! Did she have the matching dryer?
Thanks for the pictures Greg!
Brent
Yeah, the Calypso machine and also the Maytag Neptune machines are great washers-when they work.
You know what I would love to see, a was test... testing the calypso with different loads, stains,... would nice to see that the invention really worked well!!
Oh yes an other thing... I don't understand that there is only 1 bearing supporting the tub, at the bottom... But why is there no second bearing around the tub like in a frontloader. It would support the tub much better and preventing the inner tub to hit the outer tub by any malfunctioning... or am i completly wrong?
Continuing with the refurbishment and clean-up. The cabinet rust areas have been treated with POR-15, have a bit more of that to do on the lid. Here's the wash plate with the outer dome removed, showing the inner dome.
Calypso time!
Great thread! I picked up a Calypso washer about a week ago. It sat on my truck for about a week, and leaked water all over the floor. I was going to just scrap it, but took a look see underneath. Nice and clean. Found a hose off, and 2 pair of women's panties jammed in the pump! Hopefully that's all that's wrong with it.
I'll see if I can get a pic or two.
kennyGF
Kenny -
If you found some ladies' dainties in the water pump, then make sure the gray ring that runs around the outside edge of the nutator is still good and on tight. That gray ring, if it breaks or wears out, can allow foreign objects to get in under the plate, which is open to the water pump intake.
Water has gotten into the u-joint, it must be replaced. The boot is intact so the inner wash plate seal is likely the culprit. I found a dollar in quarters in the basket, so I'm wondering if maybe the previous owners opened it up to retrieve something and didn't replace the seals.
omg!
dadoes, this is a lot of work for you! i don't know how you do it but man have you revealed that those calypso's hold in dirt don't they? ive read that they are the worst at leaving grunge within the outer tub and sometimes a smell but not until i saw it now did i believe it! best of luck and i hope the hard work paid off.
V
All the crud in there
confirms that the previous user did not use low sudsing HE detergents. When low suds detergents are used, the suds level between the basket & outer tub is generally no more than 6-8" above the 3-5 gallons of water used per recirculated wash fill. An amount that the machines recirculated and spray rinses can easily get rid of.
Louis, hello there! This machine is designed to work with a highly concentrated low suds detergent water solution. This is necessary to remove the soil from the laundry and keep it suspended in the wash water. Then it can be flushed away by the spray & recirculated rinses, not deposited inside the machine.
When low suds detergents are not used, residues are carried high up into areas of the basket-tub by the weak but sudsy wash solution. The excess suds also greatly reduces the recirculated water stream.
I brought mine home last weekend, replaced the pump and got it installed in the garage this weekend. I've run most of the week's washing through and it works beautifully. Mine had almost no scuz & crud around the tub, basket or other parts - I thought it was actually a tribute to it's owner's fastidious care and feeding! It was used by a family of five for four years, so the normal amount of lint and residue had collected around the top of the tub ring, etc. but it was nothing to clean that up quickly. There is a nozzle inside the outer tub at about the 10 o'clock position that sprays the outside of the basket while it's revolving for a few seconds - there must have been a ton of suds in your washer, Glenn.
The suds, combined with harder water conditions will do exactly what you see there. There is a reason the machine calls for low sudsing detergents! What a shame man....that's really filthy, and most definitely shortens the life of the machine.
There are several small rust spots under the rubber gasket around the top. I need to pull it for proper cleaning and treatment ... but I'm leery of being able to get it back on. There's a tie-strap threaded through the gasket holding it in place, and the tail has been snipped. Even if I could get the connector loose, I'd never get it back together. It seems from pics on parts sites that a replacement gasket comes with the tie strap already in place ... so I assume it's simply worked into place. Can anybody confirm the procedure, and that it's "safe" to pull the gasket off without running into an impossibility at getting it reattached? Or if I snip the tie strap, will the gasket stay in place without it?
U-Joint Kit
Six rubber grommets are already on the u-joint (one had come off, found it in bottom of the box), and a foam gasket is included. Another grommet set is in the package with the pink o-ring. The inner wash plate/dome is a tad beat up, but functional. It and the u-joint were packed loose in the shipping box. The leveler was sealed in bubble-wrap.
