Sounds similar to what has happened to my Calypso. If I leave it plugged in, in the morning for some reason, it starts beeping as if a button is being pressed and then it's locked up. I read online that this could be either a membrane panel problem (that was the first possibility) and/or a machine computer board problem. Not wanting to spend the $$$ for new part and service installation, I first tried a terrible hack (figuring problem was most likely panel anyway, and not wanting to go through trouble of testing panel matrix from ribbon connectors). I tore off membrane plastic cover and cut out the membrane panel trace that went to the offending switch, which seemed to be the Normal switch. Then I plugged machine in, and it no longer beeped, and it worked fine on Jeans cycle (what I usually use anyway).
Well, the next morning the terrible beeps were back, but this time no longer localized to the Normal button. So apparently I didn't really get at the root of the problem, it may have just been coincidence that I hacked the panel at night and it worked fine at night. (Though I had previously tried plugging and unplugging, I had never left it for more than an hour.)
So now I leave it unplugged during the daytime and only plug in at nighttime just before use, and so far it's working fine.
Now this still could be some sort of temperature/humidity problem with the membrane panel (or the machine computer, but less likely). But my current theory is that the problem is really in the machine computer board, somehow it's gotten flaky and doesn't like the increased AC line noise and RFI in the morning (which I can tell from how other electronic equipment works).
It would make sense that the machine computer had gotten flaky because of power surges. My house took a particularly bad surge this summer which wiped out some other equipment. I had electrician install a whole house surge protector after that. When doing so, he discovered that my ground rod wasn't even connected. That could have been another problem, and could have rendered other surge protectors in my home relatively ineffective.
