Can anyone recommend a new washer under $700 that is reasonably well built and easy to work on?
tominky
Member
Oct 26, 2021
15
La Grange
Shopping for a new washer. I am open to both top loaders and front loaders at this point, and I am mechanically inclined and not afraid to make my own repairs. Looking for a reasonably priced machine that can be expected to go 5-6 years without major repairs like seals, bearings or transmissions. And if I do have to repair one, I don't want to buy something where the replacement parts will be unavailable in a few years. I was looking at the Speed Queens, but just can't swing $1300 right now - I am unemployed and job searching. (Funny how stuff decides to crap out right when you can least afford it.) Also looked at the Maytag Commercial Series, but even those come close to a grand. I was really hoping to find a decent machine in the $500-$600 range, but that looks like a pipe dream right now. I would even consider something cheap that maybe I can sell off in 4 or 5 years once (hopefully) I am in a better financial situation. We are currently without a washer and the wife is going to have me sleeping in the garage if I don't get something soon. :-)
Checking one source, new, this is gonna be tough.
I'd suggest second hand or scratch and dent departments of larger stores.
Brand wise, I'd go LG in the budget line.
They are reasonably well made and some smaller stuff is quite easy to do.
Edit:
Best buy lists it's "open box" offers online.
While not an amazing machine, LGs budget machine as open box could fit your budget and still perform fine.
https://www.bestbuy.com/site/lg-4-5...tion-technology-white/6397853.p?skuId=6397853
I would personally opt for a frontloader if I had need to buy a new washer.
For a toploader other than Speed Queen or the Whirlpool or Maytag "commercial"/home models, consider a basic Roper or Amana.  They're the same mechanical design as the WP and MT without the claimed beefed-up components.  Bearings typically have been failing at 5 to 7 years, some cases little as 3 years if usage habits are lacking of care, perhaps some instances longer.  Spin bearings are integral to the transmission assembly, which isn't a particularly cheap repair but it is easy.  The design was introduced in 2010 so no more than 11-ish years maximum possibly longevity reference thus far.
Look for
a Roper, Amanda, Whirlpool or other budget top load with a dual action agitator. these run about $500. Don't overload and wash like items with like items.
If you go with front load, look at LG. I doubt the 4000 series with turbo wash is within the budget, but...
If u aren't set on matching pair, perhaps u can spend more on washer. A basic Whirlpool dryer will do the job.
Sometimes u can find good deals used where someone has just upgraded.
Another idea...
Buy washer new and dryer used. people are always selling the dryer to front or topload sets when the washer needs replaced. LG keeps a similar design , so u may not notice it is not a set of you decide to go with front load. my LG front load washer lasted 9 to 10 years, but I am still using dryer over three years later.
Your best bet is to get a used Whirlpool or Kenmore direct drive set since they are easy to repair and parts are still readily available for them. I’d try to stay away from the newer Whirlpool VMW washers since they are cheaply made and AW member Eurekastar had the transmission fail on a Maytag “commercial” washer since they are that cheaply made.
if you can afford shipping
if you can afford shipping from canada to where you live i would reccomend this direct drive that i had as daily driver from 1993 to 2004 inglis superbII (whirlpool direct drive, would reccomend this set but as mention in reply#7 you would need to have them check before use
Maytag mvwp575gw...
and I've had mine for over three years with no issues for 7 to 10 loads every week in my kid and pet friendly home. This washer does have upgraded parts like a belt, capacitor, bearings, motor, etc. It probably have a better electronics board too. This model is built off the same line used for their commercial washers. If you read through the reviews, people want their old direct drives back, and this is not it. Hello! Only Speed Queen makes a model with a transmission and even they added a control board that works in conjunction with it. That's a lot more expensive to replace than a splutch.
For the difference in price compared to the Roper and Amana (and many other washers), one gets a five year parts AND labor warranty. You can replace many parts yourself. Surprisingly, they are not that expensive either. Instead of a transmission, the vmw design uses a gear case and splutch. Don't overload the washer and wash like items with like items. If you go bleach crazy like a vet office might do for towels (as well as probably overload it), then I think you will have issues sooner not only with this washer but any. Though it is marketed as a commercial washer, I don't think the design is robust enough for that. However, it is better built for residential use unless one has the option of buying the Speed Queen TC5.
The deep water cycles have tap hot. The budget washers may temper hot. Even though the budget washers may also have a dual action agitator, the wash action is more robust on the Maytag. Just watch some videos of the different models.
The biggest con is the only smaller load option is Normal aka "eco" cycle. Think of the Normal "eco" cycle as a quick wash. I have a way of adding hot when needed. If I need a half tub rinse (instead of spray), I just run the load a second time without detergent.
My independently owned retailers sells this for around $850 whereas Lowe's is asking $950 with four years LESS warranty. If you buy online, I have seen it within the OPs budget.
Finally, I may be wrong. I think the person that had the Maytag later bought a SQ TC set and now has a frontload? Nothing wrong with being a washer enthusiast (their information and experience can be invaluable!). Sometimes, people's needs change too or circumstances may have necessitated buying a washer that used less water. But most people buy the appliance and intend to use it until it costs too much to repair. The Maytag only came out in 2017. It is still under warranty. It is possible he got a lemon though. With that said, SQ has some lemons too. You will NEVER see that mentioned especially in regard to some of their TR models (and I'm not just referring to wash action that doesn't work as well for some types of laundry).
The reality is people on this board trade out washers like most trade out cell phones. Many also have the skills to repair them, already have the tools, and may even be able to get the parts for costs. It just bothers me when I see the Maytag trashed. Bottom line is it is the BEST cleaning performance top load on the market period. And it is the second overall best, but you may determine that is the GE Commercial is depending on what's most important to you.
My next washer would be the TC5000 because I will be doing more smaller loads. I may even get it while I still have the Maytag--something I've never done before. Where I live they are hard to get and the few places that are selling them are selling them above retail. No. Thanks. If I ever see it for a decent price again, I'm getting it. It doesn't look like the washer situation will ever get any better :-(.
feel free to check this thread that i made
When my mom bough a new washer dryer for the summer cottage i made this thread asking for info so feel free to check it out in the end final post you will see what my mom finaly chose for the summer cottage https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?88621_11 and here a small vid of my curent daily driver in action at the start of the main wash
If you're lucky and have a Habitat Restore go check them out. Timing is everything but ours frequently have a decent used washer or dryer for sale. I've seen some real beauties over the years and their prices are decent in the $200-250 Cdn. range. Plus they do test them as best they can.. downside is you can't return it other than for store credit, at least at ours you can't.
Buy used
You can get better cleaning and more cycle options if you buy used. The trick is finding a used appliance store that will stand behind their sale. There are a lot of resources online about how to find a good, used machine. I would recommend watching YouTube videos from Lorian Furniture, they have one that discusses buying used and the old-style direct drives.
I've seen good options for machines at my local Habitat Humanity Restore. If you have one nearby, it would be worth a visit. My store hooks up the machine, runs it through a cycle, before it hits the sales floor. If I were to ask if I could watch it perform before buying, I think they would oblige. (Hint, hint).
But, if it must be new, my mother recently purchased a GE washer for around the $600 range, but that included delivery and haul away. She bought it from Costco which I believe extended the warranty out from 1 yr to 2 yrs. They do vet their products to a degree, so I felt a bit better about the purchase she made because of that.
There are definitely better machines than GE out there if you look.
A used Speed Queen made by Alliance would likely fit your budget.  If you get a lightly used one, you could get many years of service from it.  You would also be able to find one with knobs and dials instead of a cheap and annoying electronic membrane panel.
If you're on the Nextdoor on-line platform for your neighborhood, check the "Finds" page there.  I often see items people are giving away that are new, or nearly new.  I recently scored a top of the line GE cooktop that sells for as much as $2400 -- new in open box -- for free.  I realize I live in an area with much higher than average disposable income, but it's worth checking regardless.
I may run by the local Habitat store just to see if I get lucky. My issue is that the wife is rapidly losing patience (can't blame her really) and does not trust the idea of buying something used with no warranty. I guess I could try an appliance store that sells refurbs - a lot of those offer 30 or 60 day warranties. I went over and looked at a washer that my nephew had used years ago. I think it was an old GE that looked to be from the 80's. I decided to pass because it had obviously been sitting for many years and appeared to have some issues. And it would be hell to get it out of the basement it is in.
Thanks for all the suggestions. I'll go out hunting tomorrow. Still tempted to try to stall the wife long enough to get my old Amana running again. Aside from the plastic tub, it is basically a Speed Queen under the skin.
I went out to a local appliance retailer who is a SQ dealer. He had one Classic left, but $1200. Whew. He also had the GE Commercial for 900-ish. One interesting one that he had was the GE "commercial grade" unit for $750. I was told this unit has a 5 year parts and labor warranty, which makes it more attractive. Model # is GTW525ACPWB. Anyone know anything about these units? I have never been a fan of GE products, even though they are made right here in my hometown, but maybe this one is different.
I also went back and looked at a used Amana that I had traded texts on. I swear, this thing looks EXACTLY like the new TC5000. I went home and Googled it, and this thing has all the same guts as the Speed Queens, including the steel tub. And I could pick it up for $75! The down side is that it is two hours away, and I doubt I would be able to talk the wife into buying a used washer. She has been pretty patient with all this so far, but today she had to hit the laundromat to get some wash done. Doubt if that patience is going to hang in there for much longer.
For the money you can’t beat the Roper RTW4516 or the Amana NTW4516. They are identical except for the color of paint used on the control panel. I’ve had my Roper RTW4516 for 17 trouble free months. It’s a simple machine that allows the flexibility of either a lower water wash with the Auto Sense water level option or a full fill, and I mean right to top of the tub with the Deep Water water level option. The Auto Sense uses and adequate amount of water to clean thoroughly. With the Deep Water option the roll over is just like the TL’s of yore, very impressive. Since I live in California and we are in the midst of a historical drought I only use the lower fill Auto Sense, except for our Cal King bedspread.
I almost always use the Normal/Regular cycle with Auto Sense and Hot water and the cycle completes in 35 mins, with the Auto Sense/extra rinse it takes 50 mins. Both machines are right around $500.00 even with the currently inflated prices of appliances.
How easy they are to work on I don’t know. But as simple as they are I suspect they wouldn’t be any more difficult to work on than any other modern day washer.
I wash a minimum of 4 loads a week and have never had any problems with mine. No unusual noises, no failure to spin or start. I just set the cycle selection and press start and in 35 to 55 mins (depending upon the options selected) the wash is done.
It may not have the longevity of some other washing machines, time will tell on that count. But with the current options now available, if this Roper were to bite the dust and be irreparable I’d replace it with another one just like it, thats how much I like it.
Eddie
Anything is better than going to a laundromat, especially during a pandemic. I personally like the videos I've seen on the Amana and it was the washer my serviceman recommended to me when I asked. (Not sure why exactly). Good luck!
Repairguy, you are right - the one that is two hours away is in fact older than mine - it is an Amana "Commercial Quality Washer", model# LWA40AL2. I looked up the parts list for it and it uses the better metal/porcelain tub like the Speed Queens. In fact, it looks dead like a Speed Queen in every way except the name. Mine is also called a "Commercial Quality Washer", but it is model# ALW480DAW. It also has the Speed Queen components, but it must have been made after Amana was sold off because they had switched to the cheaper plastic tub. I sure wish mine was the older model, I would be in good shape, as parts are available for it.
I am really tempted to go get the LWA model and just swap the motor/pump/transmission module with the new brakes and bearings over to it. I think the seal/hub kit that I bought will also fit the LWA. I would then essentially have a rebuilt Speed Queen machine just like the new $1200 one. If only I could convince the wife. I'm tempted to just get in the truck tomorrow and make the 4 hour round trip to get it. I have driven further for less!
Fire up the truck and go for it!  If money is tight, you compromise.  It's that simple.  What if something else needs an unexpected repair in the near future and you've spent a bunch of money on a new machine?
Tom, you are a capable and resourceful guy.  That should not go unappreciated at a time like this.
I’d go for it for the price. They really are good machines. A lot of them went to an early grave simply because repair folks didn’t want to spend the time to fix them. The biggest issue was a poor quality seal at the time and it would ruin the upper bearing. Probably close to 90% of the repair folks told the customer it was the transmission when it was not. The only time I replaced transmissions was when oil was getting on the clothes because of wear in the top shaft area and it was on machines that were at least 10 years old with heavy use. I hope you get it. I always liked these and even saved a couple from when they were still commonly seen in use.
Thanks RepairGuy. I might go get it even if I can't convince the wife against buying new. We have a daughter in college who will need a new washer in the relatively near future.
Question - you mention all the seal issues - did the Speed Queens have the same issues? I see that they went with a different seal design at one point that appears to be a two-piece seal that is pressed into place by placing a ring over the inner seal and using the hub to push it down. Did this design alleviate some of the leak issues?
I can’t speak for speed queen during that time period in the late nineties as they weren’t building residential machines during that time. The seal issues if I remember correctly were corrected by using different materials to make them.
