After further research and investigating from AW.org threads...visual
comparisons and gu-estimations...the Vari Flex agitator could possibly handle
large capacity washloads...and effectively I might add. When I saw the video of
the Maytag A806 with a Kenmore Super Roto-Swirl agitator
in action, I was amazed and became fascinated with thought of other agitators I
could use in my 712...the Vari Flex is my 2nd choice as best performing Kenmore agitator beside the Super Roto-Swirl
...discovered the Vari Flex agitator base is about an 1/8" smaller than the Dual Action agitator and slightly bigger than the Power-fin agitator
...and will take up 1/2" more of space at the bottom of the tub once the vanes are set to HI
The Vari Flex agitator will actually out perform the Power-fin because it is quite capable of very good rollover when overloaded...Power-fin can not!!!
The standard capacity Super Roto-Swirl agitator have been used in 1982 Large or Extra capacity 2.80 cu.ft washbaskets...see pics
1982 Kenmore Large capacity with the Super Roto-Swirl...see videos
