V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #1 here you are some of the many pics I made of my last restoration
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #2 disassembling... .
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #3 fiding the right problem .
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #4 here you are out the outertube .
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #5 the problem to be found on... both side drum shafts
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #6 the solution? to rebuilt them both!
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #8 and then both bearings supports ...
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #10 and then the re-assembling ...
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #12 and at end... what about to try it now?!
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #13 and for you sudsy drum lovers.... here you are the videos!! <object width=425 height=344><param name=movie value=></param><param name=allowFullScreen value=true></param><param name=allowscriptaccess value=always></param><embed src= type=application/x-shockwave-flash allowscriptaccess=always allowfullscreen=true width=425 height=344></embed></object>
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #14 and the spin!! apart from the check spin I did with drum empty... nextly the final cycle spin... undressed!!!
V vivalalavatrice Well-known member Joined Dec 22, 2005 Messages 1,031 Feb 25, 2009 #15 SPIN!!! and then the download... <object width=425 height=344><param name=movie value=></param><param name=allowFullScreen value=true></param><param name=allowscriptaccess value=always></param><embed src= type=application/x-shockwave-flash allowscriptaccess=always allowfullscreen=true width=425 height=344></embed></object>
T tlee618 Well-known member Joined Sep 5, 2004 Messages 3,407 Feb 25, 2009 #16 Diomede, that is a really neat machine. It looks like you put a lot of work into it. The video was fun, thanks for sharing it.
foraloysius Well-known member Silver Member Joined May 21, 2001 Messages 12,855 Location Leeuwarden, Friesland, the Netherlands Feb 26, 2009 #17 That machine reminds me of the Zanussi toploader my grandparents had. Don't remember the model name right now, but it only had a timer knob. Wonderful that you saved this machine.
