perc-o-prince
Hi all,
Has anyone had luck repairing cement? The bowl cracked maybe 10 years ago and I was able to repair it with an epoxy, then used a sealant on the crack (that's the crack you see going from about 3:00 - 7:00 in the photo). It's been fine since, until...
I noticed it wasn't holding water like it used to but the original repair is still good. I looked closer and found a few little cracks starting. These allow water to seep at the rate of maybe 2-3 drops per minute. Id like to put a thin layer of something inside the bowl as well as over the bottom, but there are so many products out there!
I saw this one (see link) and like the description because it bonds to the existing material and has structural strength.
Any ideas?
Thanks,
Chuck
Any ideas?
Thanks,
Chuck
Loading…
www.homedepot.com
