Cement birdbath help
perc-o-prince
Oct 23, 2005
5,199
Southboro, Mass
Hi all,
Has anyone had luck repairing cement? The bowl cracked maybe 10 years ago and I was able to repair it with an epoxy, then used a sealant on the crack (that's the crack you see going from about 3:00 - 7:00 in the photo). It's been fine since, until...
I noticed it wasn't holding water like it used to but the original repair is still good. I looked closer and found a few little cracks starting. These allow water to seep at the rate of maybe 2-3 drops per minute. Id like to put a thin layer of something inside the bowl as well as over the bottom, but there are so many products out there!
I saw this one (see link) and like the description because it bonds to the existing material and has structural strength.
Any ideas?
Thanks,
Chuck
https://www.homedepot.com/p/Rapid-Set-25-lb-Mortar-Mix-04020025/202207958
Rust-Oleum has a 2-part epoxy that I recently used on the floor of our front porch before painting it.  The man at Ace Hardware recommended it highly and said he'd used it on his birdbath and a flower pot.  It worked well on the porch floor and I'm going to use it on our birdbath next.  Was easy to use and can be sanded & painted once it's cured 24 hours.
Thanks Gansky. Is it a rigid final product capable of taking weight? Or flexible? How's the adhesion factor?
Paul-thanks, but trying to save the structure of the original. Cool easy fix though!
Chuck
Thanks guys, but the idea is for whatever I use to be somewhat structural because this birdbath has been here for 50+ years and somewhat sentimental. If it were just a case of sealing, the clear Flex Seal would have already been done.
And Thomas, no! The little "darlin's" already have fountains enough here to frolic in!! LOL!
Chuck
Thanks, Thomas,
... but as I said, this needs to be a structural repair. Flex seal and a skim coat of plaster will not accomplish the goal.
I bought the Rapid Set mix linked above after consulting with a mason. Gansky- if I wasn't looking for structural for a heavy piece, the Rustoleum was tempting. He said if it was a lighter and/or thinner piece, the Rustoleum would be great.
Fingers crossed- hopefully I can get to it tomorrow or Friday!
Chuck
This epoxy dries rock-hard and can be sanded after curing if needed.  I sanded mine on the floor and primed/painted it.  It's only been a month or so, but so far it looks good.   I also used it to reattach a small chunk of the porch floor that broke out around the front of one of the iron support pillars when the old concrete steps shifted and pulled the railing.  We've removed the railing completely now so that won't happen again. Since it was a vertical surface, the epoxy wanted to ooze out so I used a sheet of Glad Press & Seal plastic wrap to hold it in place while it set.  Worked like a charm and peeled off completely when it was dry.
I can understand the sentimentality, my birdbath was made by my late grandfather around 1986 when he was 80, the last one he made after making numerous for family and friends through the years.  He saw the pattern in the newspaper, cut it out and a few days later, had it standing in his yard, prompting requests for more.
Thomas, it's not the weight of the birds... it's the weight of the cement! LOL!
Gansky- I never thought of Press & Seal!! I repaired a cousin's one-piece steps and had to fill some vertical areas- I used duct tape. It removed pretty cleanly... well, most of it! I had to take some solvent to some of the adhesive afterwards. Definitely going to keep that in mind as I noticed some new repairs are needed to those steps! Does that epoxy fill gaps well? And does it have a high adhesion factor?
Chuck
There is also mason caulking that you can pick up. Used it on my chimney years ago and it is still holding up. Had cracks in the mortar and water was getting in. It was gray in color but you could repaint the whole thing after. Very easy to use in a caulking gun.
Jon
