People who own them swear by them and say they will never use another range again. Mine is still undergoing restoration but I fixed one up for a friend to use as a spare in her garage. She loves it and now does a lot of her cooking out in the garage. The oven and deepwell are super well insulated so you can cook on retained heat - saves gas in the long run. You can basically preheat the oven, slide in a roast, leave the gas on for a couple of minutes per pound, and then turn it off and go spend the day looking for more thrift store finds. The roast will be done perfectly and will still be warm when you get back home.
Chambers designed their ovens specifically to be used with Lisk roasters which came in 6 sizes: 0, 1, 2, 3, 4, and 5 -the biggest. The big no. 5 Lisk can hold a 25 lb turkey and fits in the oven at an angle with the oven racks removed. The smallest Lisk roaster holds two Cornish hens - barely.
One thing - Chambers are heavy! The average residential (38") Chambers weighs 465lbs. When moving, you can remove all of the burners and the heavy oven floor to reduce weight. It is also a good idea to remove the side panels (two small bolts) so that they don't get damaged.
Chambers were available in several colors including pastel blue, pastel green, pastel yellow, Freedom Red, black, pastel gray (rare), and copper. There are three common models: A (mid-1930s), B (1938-1949), and C (1949-mid1950s). The C was replaced by the MR-9-H, also called the Model D, which has updated Mid-Century styling but is currently not that popular (I bet it would be here on this forum).
Chambers are famous for their Thermowell but some models had a high BTU burner instead of the deepwell. Another favorite is having the broiler under the griddle on top of the stove - no bending down to slide open a drawer broiler. Some owners have two griddles: one to use and one polished up for show when company comes over. The griddles are made of aluminum and get dull with use. They also warp sometimes but are easily flattened with the use of a rubber mallet. The daisy burners work well but the Model D (and built-in stove tops of the same time period) changed to the "Plane of Flame" burner which several on the Chambers board say are even better. A few have replaced there daisy burners with the plane of flame burners.
Here are two Chambers forums you can check out:
http://chambersrangers.proboards.com/
http://chamberscommune.proboards.com/index.cgi
Here is a very good thread on the first forum about moving a Chambers:
http://chambersrangers.proboards.com/thread/1575/moving-chambers-stove
Here is a page showing most of the various models that Chambers made. At the bottom is the Imperial, which is what I'm restoring but mine is the next size up - 65" wide and weighs about 1000 lbs:
http://www.chamberstoves.net/Models.html
[this post was last edited: 10/27/2013-09:20]
