slowspin66
Tub removal
To get the tub and gear box out you need to remove the clutch housing and drive and brake cone from under the machine . The gear box and tub ( all attached ) will slide out upwards ..
I really wouldn’t open the bell housing on the gear box unless there is a known problem . Did you get the service manual okay ? The only time you would need to get the complete unit out is to service the snubber seal … call me if you get stuck . Regards Darren
