Classic UK Appliances & Kitchens - March 2015
vacbear58
Sep 22, 2009
5,043
Sutton In Ashfield, East Midlands, UK
March already!
Ok, lets kick off with an item that appears in these threads fairly often - a S/S Tricity oven. These appear so regularly that they much have been one of the most popular built in cookers of their time.
It so happens were will be able to trace the development of the same model over about 10 years of so. So, we start with the earliest - it says 1970s, it could actually be late 1960s as well
And now mid 1970s
Actually this is a later version of this particular variations as the oven temperatures are in centigrade. Note the grill handle is now full width and the timer is swopped around and push buttons for oven light and rotisserie. When I look back at the white Tricity oven I posted a week or so ago it indicates yet another iteration between this listing and the last, with push buttons but conventional clock timer and temperatures in Fahrenheit.
And on to late 1970s
Much the same as the last but new style knobs. Look how the ventilation grills are much larger, I suspect this was to make it match 120cm height module rather than an old imperial size. It also shows a return to toggle switches last seen on the single oven version contemporary with the double at the start of the thread
From the same seller as the last Tricity above
Credaplan Hob - this looks like it has given long service but then it could be up to 40 years old. Actually I suspect that it is older than the Tricity which seems in much better shape. This hob is my favourite of all radiant ring hobs - mind you I would have expected a dual ring on something like this
