so now I am officially in hock for 360 payments (or until I die, whichever comes first)
Closing took an hour and half. I signed so much crap I think I gave birth...........to a real estate agent!
Started moving some things today. Measured for the umteenth time the space in the laundry area for the Speed Queens. I have 6 foot side to side o they WILL fit.
Knocked out the drain plug for the washer.
Fiddled with the stove. Smooth top. Heats quickly I found out. Very quickly. Oven works sans the inside bulb. Stinks a tad due to newness.
Ran the BOL contractor grade Frig dishwasher. That mother is NOISY. I mean like jackhammer noisy. Will be running it at night for sure lest it interrupts my Lawrence Welk reruns!
Studied up on the Goodman furnace. Indirect venting setup. Screwy and probably expensive Aprilaire accordion type filter. Figured out how to remove it. Learned the T-stat. Outdoor unit is also Goodman, contractor grade. At least it was run with R410A.
Turned up the Bradford White WH a bit. As from factory, it was barely lukewarm and I like to see red skin when I shower.
Installed 2 made in Vietnam cheap blinds in the garage.
Installed the effing mailbox. Don't ever buy those so called adjust to fit brackets. They suck. Once you tighten the cheap chinese screws, ya NEVER will get them apart.
Spoke to neighbor to be who happens to be....a contractor! Likes firearms too. Wasn't too up to snuff on Speed Queen but he said he'd take a look when I moved them over.
Spoke to mailman. Mail comes sometime after 3. My street is last on his route. He looked over the mailbox declared it to be ok shook my hand and off he went.
Sitting here now waiting on to hydrocodone to kick in as every muscle plus knees hurt like a bitch right now.
And I've only just begun the heavy lifting!
Stay tuned.
Stay tuned.
