Clothesline Rules!
Line drying dosent make clothes stiff (like jeans)
Its the amount of detergent left in them that makes
them stiff.
Someone isn't rinsing enough to get out all the detergent.
If your allergic to fabric softener (like I am) you can
pour 2 cups of white vinegar into the last rinse water and
the vinegar will cut the detergent thats left and help soften
the clothes.
The odor from the vinegar does dissipate and I promise you
won't smell like a walking salad.
One More Rule
Don't hang out any clean laundry to dry until after the trees stop putting out their pollen. Who wants tree pollen on your clean laundry. You can see how it coats everything outside at this time of the year, and you don't want it on your clothes.
Doug
Creative display of color
Was once driving through Province Town. Saw a clothesline with only colored items, hung in progressive order, forming an obvious rainbow. Perhaps there was a parade planned for later that day.
No one has mentioned clothespins or types of rope for the line.
Are there favorites? I use the standard wooden spring clips but I'm getting annoyed with the rust and having to bleach them to get rid of the mold. Also, have always used natural rope but am also getting tired of the mildew/mold. I'm always tempted to buy the colorful plastic pins I see in Asian markets. Do any of you use the old fashioned non-spring wooden pins?
I use plastic coated steel braided cable (available at HD or Lowe's) for the clothesline.
And plastic spring pins I get at Kmart or Walmart.
For the pulleys, Wright Alum Co. cast aluminum pulleys. Far better made and safer than the stamped steel things.
Use the wooden and plastice. I bring them in the house when I am done. This prevents from rusting. Now for the pulleys is is EVERLAST, a high impact lastice with cast aluminum. The pulley on the pole lasted over 20 years.
My Mom, sister, and I always bring our clothespins in after taking down the laundry. My Mom has most of the pins that she first bought when they were married in 1967. And, my sister has quite a few of our Grandma's clothespins as well, some of which are just as old or older than Mom's. My Grandma had several aluminum pins as well which are actually quite nice.
I've noticed that most of y'all relating fond memories about hanging out laundry are "up north" or, at least, not in deep south. Growing up in south Texas near the coast, half of our back yard was usually a vegetable garden every year, and within 10 or 20 miles were several chemical plants which pumped out all sorts of nasty smells. I remember that whenever my mom would hang the clothes out, they always had an unpleasant "dirt" smell to them when she'd bring them in, so she usually used the dryer as a result. This was in the late 60s-early 70s, at a time when those nasty *shiny* polyester shirts with loud prints for kids were "in"...those shirts always smelled like the dirt in our garden after hanging out to dry. Between the dirt smell, the smell from the nearby chemical plants, and the 99% humidity, the dryer was IT!
I use plastic coated steel cable for the clothesline and I have mostly the wood spring loaded clothespins, but I have some of the wood pins with out the springs, which I cant seem to find more of.
What are the pulleys on the clothesline for?
All of the clotheslines in our area are simply two poles spaced about 15-20 feet apart with a cross bar at the top making a "T" shape and there are hooks screwed into the crossbar for typically 3 or 4 lines.
Sam, I am from Plymouth PA. Moved to Jersey when I was 3 but visited family quite regular. I remember my grandmother and really all the neghbors have a rust proof wire cable for lines. This was very strong and lasted a long time. You have to use the clip clothespins in order to keep the clothes on the line.
A pulley line is just that. A pulley attached to your house and the other pulley on the pole at the back of the yard. You did not have to 'walk" the wash, you stood in one place and keep hanging the clothes and pushing the line out till it reached the pole.
The pulleys are from the days when clothes-lines were found running from window-to-window within the same aparmtent or to a neighborng tree or fire-escape.
You'd add the clothes from one open window and send them further away by pulling the top line to you.
Obviously in this case you would not be able to walk on the ground to position yourself near an empty spot on the clothesline as you woueld with a fixed clothes-line.
Monday's washday here...
because it is my day off.
If the weather is decent, all whites (sheets and undies) plus the cotton tea towels go out for a good bleaching. Colors in the dryer, as my lines are on poles in full sun.
The thought of placing underwear in a place shielded from view never occurred to me. If folks driving down the road see it, so be it.
Clothes line is cotton rope. Clothes pins are wooden spring-type, and always come in at the end of the drying session. I do have a beef about today's pins however. They seem flimsy compared to the ones from days gone by. I have a good number of pins that belonged to my parents, and like those pins better. They are larger, and don't seem to slip apart like the new ones that I have.
I also have three aluminum clothesline poles that were my parents'. Wish that I could find some more of those, but have had no luck. I recall them in use when I was a kid, back in the 1960s.
Joe
FOR Chuffle (or Joe)
I'm thinking that you mean those poles that you put up along
a wide stretch of clothesline to help hold up the line so it
sorta remains straight instead of sagging from the weight of
the clothes.
If so.....I know the aluminum poles that your talking about.
I haven't seen any of those around in years, but, I got some
poles at Home Depot a couple of hears ago that I like even
better.
They are aluminum (not shiney) but are covered or painted a
dark green color plus they are adjustable for the heighth.
I love them.
I can't recall what I paid for them but I think it was like
$7.00 or $8.00 each
You can easily make your own pole by obtaining a 1x2 piece of lumber and cut a "V" notch in one end. This will hold any clothes line you choose. To adjust the height, you just change the angle at which it touches the ground.
The pulleys are not just for clotheslines stretched between two windows.
When I was a kid we had a pulley clothesline. One end was at the kitchen back porch. The other end was attached to a tree out in the yard. That way my mom could put out and take in the laundry without having to leave the porch.
I have a sort of similar arrangement. One pulley is attached to a pole that I secured to the porch stair railing (sturdy steel pipe railing). The other end it attached to a light standard that extended about five feet above the garage roof about 40 feet away. None of the clothes on the line are really reachable from the ground, and besides that I'm using the area under the line for various dwarf citrus trees in large containers.
At one time a cowbird adopted our family and would come to the window to be hand fed. But sadly one day he or she was sitting on the clothesline and didn't fly off quick enough when my mom pulled it in. Hurt his foot or something, and he/she never came back after that.
Clotheslines here used Galvanised stranded wire. Now they are pvc over a synthetic fibre rope.
We have a 6 line pull out clothes line that runs the width of our courtyard. Its in full sun from 6am to 5pm most of the year round and stuff usually dries within 3-4 hours.
http://www.onlinedirect.hills.com.au/cattleprod/products/A1501ULT
The Rotating style clothesline has been the mainstay of the Aussie backyard since they were invented in the 40's. These days the Galvanised ones have been replaced with powder coated folding ones, but most familes have grown up with one of these here.
http://www.onlinedirect.hills.com.au/cattleprod/products/A1405SU5
We've got a fold out one in the garage. Its mounted on the wall and has a big rectangular frame that encases the lines. The whole frame folds up and down, however we've now mounted it up the wall higher and just leave it up always.
http://www.onlinedirect.hills.com.au/cattleprod/products/A1601PAR
I'm just about to finish my 4th load of wash in 5 hours and the line is just about full. The first load is ready to take in. Shirts, Darks, Towels and now Whites.
Butch-inNJ :
Yes, the poles that I mentioned hold up the sagging clothes line.
Thanks for the tip about Home Depot. I'll be in the city tomorrow morning, and I will make a note to check the HD to see if they still have 'em.
whirlcool:
Thanks for the tip about the wood poles.
Joe
NOoooo, That's a washday infraction. My mother always did the whites first, I do to. I think it was throwback from the old wringer days when you reused the wash water.
Whites first
Dark items that fade like Blue Jeans last.
Ken,
I avoid pressure treated wood for several reasons...
It contains toxic chemicals that can leach into soil.
Sawing it releases dust that can cause respiratory problems (same toxic chemicals).
The cut ends are not protected from rot/decay so you should spot treat them with... more toxic chemicals.
If it were me, I'd get heart redwood or cedar instead of pressure treated pine or fir. It will last just as long with fewer environmental impacts. The natural tannins in heart redwood or cedar act as a protection against rot, insect attack, decay. But yes, such wood is significantly more expensive than pressure treated wood, and may be harder to find.
its the norm
over here even though we get lots of rain and often poor summers we still hang out clothes, it does feel good on a lovely bright sunny day to see whites on the line and if you lucky (or unlucky) to live in a windy area like me they come in very soft!
Tumble drying is a luxury, my mam still only uses her dryer to finish off clothes she has had several attempts at line dying first!
Richard
