Clothing Spinners & Spin Rinse Results
Currently aside from "Spin-X" and the other "Laundry Alternative", nothing else is sold as a stand alone spin dryer in the United States.
IIRC Maytag Porta washers spin lower than the Hoover's TT which is 2,800 rpms.
From what one has gleaned in various posts on Yahoo, here and other forums on twin tub/spin driers; unless the unit is designed for a spin rinse, doing so can cause damage. Mind you it may be easy to retro fit something, but again one would have to find the proper water to spin speed. Others would know more than I on this matter, but apparently too much water at once over taxes the motor and pump. Sort of like when some front loading washing machines slow down spinning when too much water/suds are coming at once.
I find the Hoover spinner hard to beat. It even extracts water from items spun in high spin front loaders.
You might find a small Bock extractor on eBay, but think all models had to be bolted down into concrete.
Launderess
I think there's always a learning curve when dealing with a new type of appliance. So it makes sense that it took a while with the spinners before everything settled down.
Re. spin/rinse cycles: If you shut off the motor and then run water into the spinner as it's winding down to a stop, that will get the load good & wet without overtaxing the motor (which will be off as the unit winds down to stop), and then after it stops, turn it back on again. Repeat as needed. Not exactly the same as the Hoovermatic process, but still useful.
