Coffee was RUINED -- Film at Eleven!
jetcone
May 2, 2001
7,688
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
Coffee was RUINED this morning = Film at Eleven!
All I did was go down to the basement to put a new boot into my 1957 Tower Top when I started a wash in my 1949 Streamliner since I had successfully repaired the timer. Well I was yanking the old oil bellows out of the water bellows and I had set my 1943 MIT coffee alumni mug down on the 1956 GE Filter Flo. When all of a sudden the 1949 Streamliner went into final spin but the clothes had lumped up and there were jeans in there. OY VAYS MERE! The Streamliner started hopping all around and yanking the platform with it which caused the 1956 GE next door to act like it was spinning unbalanced and so the 1943 MIT jiggled right off the 1956 GE onto the CONCETE FLOOR and smashed in a 1,000 pieces just as I arrived from across the basement to save the day.
Hi Jon, It sounds like you are not having the best of days there. It only has to get better!! Terry
Oy ve!!!!!!
Sounds like the Streamliner had too much caffeine. No more laundry for you today; could be dangerous! ;-)
Thanks Westy I just bid on that mug to replace it! Isn't ebay wonderful!!!
Louis you are correct four legs in my lap right now while I type to you! He makes up for everything!
Retromom: I still need to do socks tonight wish me luck.
Peter, A basement is a nice place to hide you should run out and get one at Base -e - ments -R US!!!
Jet
Westinghouse's don't tangle Greg! Where did you ever
So I'll say: IT was Jetcone, in the basement, with the bad loading technique ;) Al is adorable!
jet?
I believe the 49 streamliner is a bolt down westy. Is that right? I am cramming for automaticwasher.org The Board Game. LOL. alr2903
Jon, I am so sorry about the mug. A bad meaning for a mug shot. But Al is there to save the day and calm the fretted nerves!! I hope by this evening you will have calmed down enough so you could experience the therapeudic relaxation of a load of sox tumbling away, how about the Duomatic!! Bob
