Commercial Induction Cooking
Looks very, very sweet.
Induction cooking gives you all the benefits of gas, like the instantaneous control without the fumes and ridiculous amount of heat that comes with it.
It also happens to be the most efficient way of cooking - so its great news for businesses looking to cut down their energy costs/environmental footprint.
I would like to think these units are manufactured with durability and repair in mind.
We have had our Westinghouse 4-hob unit for 4 years and have been quite impressed with it.
Well Jon, there are lots of brands available on your side of the pond nowadays too. I love the Bosch ones with a 4500 Watts burner.
Although I love induction cooking, I hate it when the apparatus begins to bleep when I lift the fryingpan from the cooktop to shake things around a bit. I wonder how this will work out in a commercial kitchen. You can also see in the background how a pan is being moved over the cooktop, not too good for the ceramic top I think.
Electric
Has anyone tried any of these? I have always been told that in order for induction to work well it needs to be 240V plus more amps, making it a very expensive experiment.
For me, I think it would take a lot of getting use to.  I'm pretty "manly" when under the pressure of the 6:30 to 8:30 rush during dinner time.  Not that I'm rough with equipment, but I'm certainly not gentle with Sauté Pans on the range.
My fear is that when I grab 3-5 Sauté pans and scale them across the burners, I might crack one of those Induction Glass Surfaces. I can't imagine having one of these imaginary video Chef jobs where they calmly go about their chores. Seems like they make the industry look like: No pressure, no drama, everything is right with the world, I work normal hours, I'm Ok your OK, it's just Horse Puckey if you've ever been on a a la carte line.  Yes, I'm sure in a Commissary or Institutional setting it is a totally different pace.  But when you get these people that are designing commercial kitchens and have never worked one, well... this is why some layouts simply look good on paper but just won't work.
But none the less, they are beautiful units.
And since when have we started calling stations "Suites" ?  God I'm getting old.
I saw a blog recently where they had several induction single burner stock pot ranges in a line. I think the name was CookTek. Never knew such a thing existed.
Personally
I don't think induction will ever catch on in restaurant or commercial applications, no one has time to fool with it, a visible flame is easy to see and judge, and with a commercial venting system still the best choice in my opinion, ive never talked to a professional cook or chef yet that didn't cuss and swear at the mere mention of an electric range, I don't want one because I have a lot of vintage aluminum cookware that im not going to give up.
Like I said elsewhere, I have not met anyone that hates induction and most who tried it will never go back to gas or radiant electric after getting used to induction.
It's certainly *different*, particularly compared to a normal workflow in a restaurant, but there are many professional chefs (not just celebrity chefs) who not only own induction at home, but have installed it in their restaurants.
There's a lot to like about it in a restaurant too -- it's cleaner, it's cooler, and once you get used to the response time, you don't have to move the pots/pans to other burners to change temperature, just change the power. Also, it's way more repeatable, not that nonsense of having to look at the flame to judge the temperature -- it is exactly what the power level says it is, and you get used to that much faster than you can believe. Some ranges have the regular 1-10 power levels, but some actually let you choose either a power level or a temperature that gets maintained by a reasonably good thermostat that you can use to fry things, make candy or keep a pressure cooker at the right temp.
I say give it a try *first* then bitch. And to be honest, I have not met anyone who bitched at induction yet.
Cheers,
-- Paulo.
I suppose it is quite the investment.
Those All Clad Pans (or whatever is compatible) certainly are not 5 for $100 bucks.
Dr. Frigidaire has an induction cook top in his kitchen. I used it to heat some soup, but really didn't get a chance to "Put it through the paces".
I would imagine a Kitchen with a Current well designed Vent Hood with Conditioned Return Air would probably be 15-20 degrees cooler.
I would love to have a Range for a week at home.  It would be nice to rent one for a month to see if you like it before you purchase.
Hey Paulo.
Mark Harman
Has one as well, he is totally sold on it....But he uses all All Clad cookware.He is a classically trained chef, and the only chef I ever met who hates gas....
I thought you could buy induction "hotplates" that are portable and run from 120V like any other hotplate.With this you could try induction cooking and not break the bank.If you like it-then you buy the induction range.The commercial one shown looks nice-bet the burners and generators would be easy to replace as opposed to a household model-and their electronics sized for heavy,continous use.I would guess that the induction commercial cooker would have to be introduced and allow chefs to try it.It is unusual to see electric cooking in commercial places---COST!!!!!
Rex: yes, one can in fact buy one of the 120V induction hotplates, they start at fifty or so bucks. Better units cost closer to a hundred. The thing is that they do highlight response time (and some have the thermostat), but they usually are only 1200W (the top one seems to be 1800W), but due to the way they are built, they usually only heat a 6-7 inch zone in the pan. That is usually enough for a small/medium pan, but not for larger ones.
Better burners (in ranges) can use much higher power (due to 220V, power boost and/or power sharing), but a lot of ranges have burners of different sizes to match the pots/pans and provide a much more uniform heating of the entire pan bottoms.
Eddie
is right I have had a 1985 Induction cooktop for the last 15 years. It was an afterthought as I had purchased a DCS gas cooktop with a flattop - we had all DCS stoves in the restaurants I worked in. They were/are work horses, I heard recently DCS was sold so I no longer know where they stand commercially since I have been out of the restaurant business awhile.
I LOVE THE flattop I gotta say! I do a lot of Wok and wanted the 17,000 BTU's of the DCS which works perfect for my large cast iron woks.
However John told me I needed an induction cooktop as well; which he graciously gave me and I installed it.
I have to say now after 15 years 95% of all my cooking is done on the induction! Once you get used to the 1-10 settings and know what they mean its dirt easy to use. And in August all my indoor cooking is done on induction, I never turn on the gas.
Also you can use cast iron pans which don't cost the earth.
I have been careful with the top, I don't drag across it . Yet things have fallen down on it from the ceiling and it has never bothered the glass. On my unit the glass is from Raytheon, it was the deep red glass developed for the ICBM's nose cones so they would be radar transparent. When the US stopped building that style of ICBM the market dropped and Raytheon looked around for another and found cooktops as a customer. Now I think all the glass comes out of Germany and is Ceran labelled. I have not used that glass.
I  was the one who pointed Mark to the CookTek line, he loves his!  I did see an installation of the CookTek unit placed directly under a granite counter top!! Granite is transparent to EM waves so it works fine there . Eddie all you need is granite tops in the a la carte line !!
I bought one of the 120V induction hot plates
It does a very good job.  I use it alot for when I deep fry because I can set a temp and it stays there.  Catfish in a iron skillet, can't be beat.
It still heats very quickly, and temp response is almost immediate, but you can't turn it on high for too long or it blows the breaker.
It's also great for cooking stuff like pasta, because you can set the timer and it automatically shuts off, and beeps.
Mine will boil a quart of water in about 3 min.
Induction cooking is made easier to comprehend if you ever paid attention to the percentages of heat that were outlined in range manuals, and the old Frigidaire Range drip trays, for the 5 heat electric surface units.
High is 100%
Medium Hi is 50%
Medium is around 30%
Low is between 20 & 15%
Simmer is around 10% or less.
Most people who go from gas to induction say that it is too hot and burns everything, but they are dealing with incredible speed, using settings that are too high and are not familiar with the percentages of heat except as flame height. With induction, the heat is happening right in the base of the pan. You are not transferring heat from another source to the pan. Several years ago the food section of the NYT did an article about having chefs try an induction unit at home and those were the problems they encountered. You don't pan fry at 80% power. A medium flame would be a 3 or 4 on a 10 power level display and people cannot at first realize that so much cooking can be done below 40% of high heat, but a lot of that is possible because of the extreme efficiency of induction cooking. You are not losing heat to burner grates or coils that are not perfectly flat under the pan because all of the heat is being created in the pan. Another nice feature that I like on one of mine is that after you have set the cooking power for the operation, you can set a timer for how long it is to cook before shutting off; nice if you have something else to do while brown rice simmers. Deep frying is amazing because the oil is hot in a couple of minutes.
Fagor is a large producer of commercial induction cooking equipment and a few years ago reported that sales were very good in commercial kitchens. The virtual elimination of waste heat made management happy because less heat filtered into the building from the kitchen. The kitchen staff was happy with the cooler kitchens and the cooks were happy with the speed and responsiveness of induction.
