peterh770
Issues, issues, issues....
It is very elementary, my dear Watson. An agitator washer beats clothes clean. The straighter the vanes, the more beating occurs. Beating causes damage, maybe not visible to the eye, but it is there. There is also chemical damage from additives, but we're not discussing that here.
Every time you clean your dryer lint screen, you are cleaning the damage that occurred in the washer that did not get flushed away or caught in whatever lint filter may be inside the washer. Some washers will cause more linting depending on their agitator/speed/time. More heavily loaded machines will cause more linting as the load has less room to move and remains in contact with the "thrashing blades".
Therefore, a heavily loaded Roto-Flex machine will probably cause more lint because the 6 vanes thrash away while the load struggles to roll over and get out of the way. The Roto-Swirl has the built in ramps which helps roll over, along with its flat paddles to do the cleaning. My guess is that more lint will be found in the dryer after drying a Roto-Flex washed load than a Roto-Swirl washed load. But IMHO the Swirl is just as damaging because of its size.
So when we look at ALL agitators, we probably find that the ramp agitators of Hotpoint, GE, Easy and Westinghouse are quite gentle with their suck down/burp up action, while the straight vanes of Maytag, Speed Queen, GE and Norge thrash up a good amount of lint.
Last, why do you think us aficionados don't like direct drive WP/KM Thrashmore washers -- straight vanes, faster agitation speed, auger forcing the loads down?
Frontloaders may be a scam, in your humble opinion, but if you have one that uses the right amount of water and tumbles at the right speed, it beats all.
Except for Frigidaire pulsators, but all knew that already...
