Not car suspension components, rather dampening straps. There are 4 of them in each model T and Modern VMW.
Here is a vid:
Here is a vid:
You could literally feel and watch the cabinet twisting on full loads of regular clothes, I.E. cotton/linen.@GELaundryforEver: Yes indeed! The inner and outer tub would vigorously shake back and forth while the suspension rod sockets would loudly groan and the entire frame would just squeal. The noises were thee most awful. Rapid fire squeak groan squeak groan squeak groan squeak groan squeak groan squeak groan squeak groan squeak groan with some other nail on chalk board self destructing noises poking through on top of it for the whole duration of the agitation and it felt like you're ears had been violated in more than one way.
It was also that shacking that would often break the tub straps, resulting in the tub banging against the cabinet during spin.
The whole concept of suspending a short stroke tub brake transmission driven agitator with an instant spin cycle engagement low slip rapid acceleration clutch on 4 springs with thin rods is simply not practical.
Every other washer that mimics this system compensates for it by snubbering the tub and/or gearing the cycle so the tub does not oscillate or shack back and forth to such extremes during wash and spin ie a ramped spin and weak/no brake so the inner tub moves and not the outer tub.
Overall a very bad choice made worse by aggressive cheapening.
Especially after seeing the Whirlpool Design 2000 video, I'm now convinced more than EVER that Whirlpool was way ahead of their time. And don't even get me started about the underwater muffled banging from the dual action agitator.Which resulted in the most horrendous noise. The grinding noise of the suspension followed by the screeching of the outer cabinet. To bad more people did not make their own noise about it.
That commercial should've went to Whirlpool. That was really the washer of the future. Ultimate precision machine. That's a lie! GE lied!Design 2000 is the washer they are technically speaking of in this video, not the rancid model T. Design 2000 was novel and did not come from any old ideas.
I am still angry about this! As if GE was built tough! Whirlpool was agitated no pun intended and rightly so!It absolutely should've gone to Whirlpool and its a borderline criminal that it didn't. The misapplication is what makes it so maddening.
Well, Whirlpool built the DD until 2011. GE couldn't even launder nor last in a laundromat or college dorm.The model T was vengeance for the durability of the filter flo while letting them milk the remaining equity out of their name.
