Very long final report
WELL... Most of my belt drive washer repair/rebuilding has been on old Maytags because they are so simple IMHO to repair, though I have heard just the opposite from almost every repair person and rebuilding shop I ever spoke to. Most will NEVER even touch a Maytag. STRANGE. Anyway, years ago I bought one of those large lots of Maytags that was supposed to be bound for Mexico. It had 84 washers and 21 dryers (I actually prefer Whirlpool/Kenmore to Maytag on the dryers as far as working on them) and they were going to deliver to the border (about 400 miles round trip) for a total on the load of $1500. I offered them $1000 cash and would take them directly with no delivery required as my brother had a trucking company. They jumped at this one. Of course they got them free. Transportation was their only cost.
My point in mentioning this is that out of all these (a few total junkers) I only found ONE Maytag that had a defective timer. I was able to rebuild and sell over half of them mainly using parts from the others (exceptions were belts and new tub bushings and seals) for approximately $60 each on average and although I worked my ass off, I came out with a decent return. The 4 Kenmores I just got for $10 each included 3 which had the same timers as mine (2 were 376011 and 1 was another 376008 like the defective one I already had) and ALL were bad. When I took them apart they were in terrible shape. Several had vaporized switch contacts, many pitted and unusable contacts, and all 4 (including my original) had bad melting on the cams that corresponded to the switches which had overheated. One had the switch terminal that powers the little timer motor completely broken. Ironically the best timer I had was one from a freebie 1971 model that I had been given years ago and had stashed out in the shed as a possible parts source. It was not the same model timer I needed, but as the cycles on the washer matched mine, I was simply able to rewire the Molex connector on my original washer to match the configuration I needed for proper operation with this good old (actually I think this had been replaced on a repair along the line) timer and then everything was working perfectly.
HOWEVER, the very next day after I finished the repair, I found someone who had a 1992 direct drive Kenmore she wanted to get rid of. She told me the washer was perfect but the dryer was completely shot, as it needed a new heating element and made a horrible noise. She would let me have the washer for $20 if I would also haul off the junker dryer. I headed ever there yesterday morning with my tools, garden hose, extension cord, and trailer. When I arrived and saw what she had I almost couldn't believe it. They looked like they just came from the factory. Outside and inside they were essentially flawless as far as appearance.
I told her I really wanted to check out the operation of the washer before I took it even for only $20 as I had already acquired a collection of non-working Kenmores over the last couple of weeks. She said sure have at it. First thing I did was look inside the control panel box. I have never seen a used washer (much less 20 years old) that looked that perfect. Not even any tarnish or corrosion on any connectors or terminals. It was shiny and perfectly clean, with not even any dust in there. I then propped the thing up and looked underneath only to find the same thing. Absolutely perfect without even any cobwebs and absolutely no rust. I popped the hose off the pump (still very flexible and soft) and it was like brand new inside. We have horrible hard water in this area loaded with calcium, magnesium and iron to name a few, so this thing must have been used only in conjunction with a water softener. When I opened the lid the basket and agitator were also the same. I could not even find one tiny pinhead size rust spot on the gleaming white porcelain finish and even the bleach, detergent, and softener cups were perfect with no build up of any kind. I connected water and power and let her rip. Operation was flawless on all cycles and settings.
I then asked if she had a repair attempt made on the dryer and she stated heck no that she wasn't going to pay a repair bill on a 20 year old dryer that was obviously shot. I then asked why she was so sure the element was burned out. She told me that it had to be as it only heated up for about 3 or 4 minutes and then just went cold and she also kept hearing a knocking noise. I told her at that point I knew her element was not burned out and asked if she had pulled the panel and looked for lint buildup and any objects that might be causing the noise, and once again was told heck no.
At this point I decided to trade a little labor for the washer, as I already had 4 working dryers. I made her this offer. If she would give me 20 minutes and the use of her vacuum and a crevice tool, I could probably get her dryer working without any problems and she could keep it and I would take the washer in return. If I did not get the dryer working perfectly in 20 minutes I would pay her an extra $5 and haul the dryer off for her as well. I figured this was a magnanimous offer she wouldn't refuse. At that point she said:
You just don't understand. These are my old appliances. I am sick of them. I have already bought brand new ones ($1500+ totally programmable "steam cleaning and drying" front loaders) and I just want to get rid of these.
I told her OK and gave her a $20 bill and started loading both on the trailer. When I got back the first thing I did was pull the panel off the dryer and saw one of the largest lint balls of all time. I checked resistance through the heating circuit and as I expected everything was fine. One of the snap disc safety thermos kicking out probably saved her house from burning down! Also inside the duct, in addition to quite a collection of multi colored sequins and large amounts of glitter embedded in the lint, I found a child's toy. This I assumed was the cause of the "horrible" noise. I cleaned everything up, checked all the electrical, put it back together, plugged it in and as you might guess, it now works perfectly and quietly.
If I had just waited a few days after my timer went out, I could have saved about $80, counting purchases and gasoline, but then I would have missed all the fun of lifting heavy objects in the 100 degree heat and several hours work only to find that all I had was a huge number of spare parts, none of which I currently needed. I am now expecting the timer on the "new" perfect washer to stop working
