kirk280980
- Joined
- Feb 1, 2005
- Messages
- 172
You could vent an electric dryer straight into the room (in fact this seems to be the norm in many Australian homes), but obviously it would then be desirable to ventilate the room itself by leaving a door or window open unless you want condensation running down the walls. The benefit of a condenser dryer is that, while it does give off some heat, it isn't exhausting moisture into the room.
Jon, a friend of mine has a Hotpoint condenser too, and that does indeed throw out plenty of heat. He mainly uses it during the winter in poor weather, preferring to line dry instead in the summer, and I can't say I blame him!
Regarding the degree of drying, I mostly stick to the Cupboard Dry setting which leaves things ready to wear or store away. The higher settings will leave clothes dessicated if you so choose, although I find this causes some fabrics to shrink.
