Got a question to toss out to all the experts. I have a 1 1/12" copper drain line from my kitchen sink and DW. A few years it developed a leak and I cut it off 4" past the problem area and replumbed with PVC from that point on. Used a Fernco adapter to go from the PVC to the copper. The pipe had developed what looked like a razor slit on the bottom. Thought it was odd but did not give it much thought.
Over Thanksgiving I smelled something like an electrical fire, a vaguely ozone smell. Looked around and found nothing and the smell came and went a few times. Yesterday I went down the basement to get something out of a closet behind the fireplace and I notice my stack of audio equipment is wet! Didn't blow a fuse or anything. The same problem developed again -- a thin slit on the bottom of the copper drain line going from the coupler back about 3". This is buried in the ceiling and not too far from this point it goes into the poured basement wall so if this keeps happening in a few years I won't have any pipe left to cut off.
Any idea why this is happening? Should I cut it back all the way and hope for the best? The whole house has copper drains, this is the only trouble spot.
