Corkscrew Agitators
launderess
Jul 22, 2004
20,858
Load sensing, corkscrew or whatever you want to call them such agitators seemed to have taken off in past.
IIRC Kenmore had them first, then when patents expired (if that is reason) everyone and their mother had a version.
Kenmore:
Whirlpool:
KitchenAid:
Even Maytag got on the bandwagon:
https://www.youtube.com/watch?v=5PGZeZm6fAU
Are these sort of agitators that much better than other designs? What gives?
I think these agitators are better suited to the direct drives and VMW Whirlpool designs.
From personal opinion, I don't think Kenmore even needed to add that agitator.
My 1974 jumbo capacity Kenmore with its Penta-Swirl handles huge loads just fine. Even with very full loads it turns things over.
I miss my corkscrew agitatior and a Kenmore direct-drive was where I had mine...
Sears used them on their Kenmore-line first, then Whirlpool acquired them, and I think when the direct-drive got introduced...
I am pretty sure my new 2-year old Maytag has a regular agitator and the entire tub is what actually spins...
-- Dave
I'm of the understanding that Whirlpool developed the design, introduced via Kenmore circa 1976 and had an agreement with Sears for it to be a Kenmore exclusive for 10-ish years ... which prevented WP from featuring such on the other brands it produced until into the direct-drive era.  Non-WP brands presumably couldn't have it until the patent expired, which I believe is 20 years.  The earliest WP patent for a DA that I have saved from the daily rotation is "filed 5/8/1975."  Three others filed 6/16/1976, 10/26/1976, and 8/31/1993.
They were what was needed for the proper cleaning action in the direct drives. But I love a good straight vane like the Maytag powerfins. The straight vanes in the DDs are garbage agitators. It seems that once whirlpool launched the direct drive with the dual actions, other brands copied them years later. Like Maytag and ge did.
Thinking about this more, it seems that the WP DDs needed that corkscrew agitator more than others. Their tubs seemed narrower than others. Especially the large capacity units with an extra deep and narrow tub, needed help to push items down to the fins.
I use my KA when I wash my king blanket. I fill the tub to the lowest water level add detergent and the blanket. Then I pull the drain hose out of the pipe and set the timer to drain and use it like one of the Calypso/Resource savers holding the drain hose into the tub to force water through the spinning blanket without any abrasive agitation. I stop it and let it soak for a few minutes then do a few more minutes of washing before placing the drain hose in the pipe and letting it drain and spin. I do a full water level rinse with gentle agitation then spin it in the W1986 before a quick tumble to dry. It is a wonderful washing machine and there are times when you just have to use the extra water and give the sewage pipes a good blowout.
The dual action agitator
Was invented by whirlpool and Patented by them, Sears bought an exclusive 10 year right to use it, whirlpool did not realize how successful it would be and how it would revolutionized top load washers, whirlpool executives expressed regret to me that they had given Sears such a long lead on it.
The dual action agitator was simply more effective at turning loads over than any other type of agitator in especially in a large tub machine even the Frigidaire one to 18s could not compete, Consumer reports called at the greatest advance in washing machines in 40 years.
While almost any agitator will turn over loads of laundry if the machine isn’t packed too full, the dual action agitator simply allowed you to wash a lot more clothing, which made top loading washers, a little more energy, efficient and extended their stay in the marketplace.
The two piece stool action agitator has been phased out because machines do not fill with enough water any longer for it to be effective. The real interest in great washers is in front loading washers today.
John L
[this post was last edited: 3/19/2025-09:19]
I don't see the need for a DAA in a large capacity belt drive with a wide tub.
The direct drives needed them more and the VMW platform definitely benefits more from them.
I've got two super capacity belt drives without dual action agitators and I've loaded both of them up to the tub ring and still get turnover.
The Penta Swirl I find is a powerful yet gentle agitator. It has that soothing wavy wash action that's even more pronounced on bulkier loads.
Just my $.02 🤷
In 1976 I was working part time at the Sears Catalog Merchant Store that my mom's friend Faye owned. I remember the Dual-Action agitator being a really big deal, and there was a Lady Kenmore washer with it on display in the store. According to Faye, the reason Sears had it as an exclusive for the amount of time it did, was because Sears was the one footing most of the cost of its development.
Mr. Archimedes.
Rest assured the man and his famous invention are quite well known, many may not know what Archimedies screw (or devices based upon it are), but never the less.
From ship propulsion to industrial washing machines, Archimedies screw is well known.
Batch/tunnel washers came about thanks to Mr. Archimedies's invention.
On another note WP sued Maytag over patent infringement when latter introduced their version of "corkscrew" agitator to Canada.
https://en.wikipedia.org/wiki/Whirlpool_Corp_v_Camco_Inc
https://www.canlii.org/en/ca/scc/doc/2000/2000scc67/2000scc67.html
Will say this though that the DAA does give more uniform turnover compared to the Penta Swirl.
I've noticed the 74 Kenmore goes out of balance a lot with that agitator in that jumbo tub.
It is very temperamental with loads that are not of the same weights
Even the surgilator in the 85 machine has more of a uniform turnover and
doesn't go out of balance as easy.
Regardless though I still really like that Penta Swirl. It's a very decent agitator for that large tub.
