Correct Way of Treating Stains
Chetlaham
Mar 11, 2013
5,292
United States
I was wondering, how do you treat stains (food/dirt/oil), especially on white? I don't want to use bleach out of fear of fading the colored hearts. Currently I'm applying Simply Tide Berry Blossom to the stains, rubbing with a tooth brush and letting it sit for 30 minutes. Is this the right way of doing it? Or do I need something like Shout?
Give it a whirl and hang dry.
Wouldn't hurt to toss some oxygen bleach in there and soak it half way through the cycle.
I have the same washer. I think using an older style washer that uses much more water you need a higher concentration of stain fighting formula than if you were using a HE machine, esp a front loader.
I have my own stain fighting recipe that was given to me by my godmother years and years ago, it is specifically for non HE machines. (I do NOT recommend using this in a HE machine.)
In a large spray bottle combine:
1 part water
1 part dish soap (top shelf: Dawn, Palmolive, etc.)
1 part SUDSING Ammonia
Mix well and let sit for a while (overnight) before using.
This recipe works extremely well for most fabrics. Spray stain and let sit 30 minutes or so then wash as usual, using PLENTY of water. Recommend 2 or 3 rinses, minimum.
I’ve never been disappointed in the results.
I also second the Biz recommendation if you don’t want to deal with the sudsing issue with my recipe.
Barry
You also have a Speed Queen? Can you post pis of it? Why did you choose or how did you end up with a Speed Queen?
I'll research and give all these suggestions a try. But to be honest the Tide free and gentle is working well. I love Tide even more now!
I bought my SQ in 2015. At the time I was caring for Dad and needed a washer that could knock out laundry quick, and one that would be very reliable. Those were the main reasons I bought it. Also be that used plenty of hot water as I was cleaning up alot of urine, and messes.
Barry
Persil
I pour Persil Stain Fighter formula on the stain, do not rub it, and set it aside for an hour or so to allow the enzymes to work. Then throw it in the wash with the rest of the load. This has never failed and it works better than Shout and other stain products, which I no longer purchase or keep in the house. Persil Stain Fighter has been changed to an Oxi formula but presumably still has all the requisite enzymes to do the job no matter what the stain.
Things can go either way
In old days stains were pretreated and largely removed before things went to the wash. This was for all but certain marks that were easily and largely removed by then standard cold pre-soak then hot wash.
Keep in mind however when soap was still queen of wash day many marks had to be treated beforehand either because soap wouldn't remove them, and or due to coming in contact with same would cause marks to be come permanent/difficult to remove later.
Depending upon who (or is it whom?) one believes modern laundry detergents with their advanced cocktails of enzymes, surfactants, chelating agents, and activated oxygen bleaching systems have removed need to pretreat many stains.
That being said in France, Germany and many other areas in Europe old ways die hard. Result is market saturated with a vast and bewildering array of stain removers with many meant to tackle specific marks commonly found in area.
For instance in France it's red wine.
UK it's beetroot and curry.
Asian nations it's soy sauce
Makers of Tide, Ariel, Persil and other top shelf offerings have told housewives and others doing laundry for years they don't need separate stain removers. Their products alone will do the job in wash.
Advent of liquid detergents (with or without various dosing devices) changed things up. In theory one does not need a separate product for most marks, just dab bit of Persil, Ariel, or Tide liquid on stain, then bung rest in wash along with laundry.
On this side of pond it was Wisk, Era, Dynamo, Tide and other liquid detergents.
https://www.youtube.com/watch?v=R6hVykvzDvA
https://www.youtube.com/watch?v=Ea3hKsph5vg
Where liquid laundry detergents have it over powders is their higher level of surfactants, emulsifiers and solvents. Things that are especially good at removing wax, oil, grease, and fat based marks.
Advanced powder detergents have caught up to liquids at some level, but overall often latter still shifts oily/greasy soils and marks better.
Over past several decades there has been a shift in laundry habits reflected by changes in how people live. Often you see less of clay based soils but more of those based on oils (body, foods, etc...). This goes long way in explaining why powdered laundry detergents have been losing market share to various liquid formats.
