WPS
These are equipped with the Miele WaterProof system.
They have 2-wall inlet hoses, both should be equipped with a double electric valve at the faucet side of the hose.
Further, the machine has a steel floor pan with a flood switch integrated into the machine base. Should either of the hoses burst, the outer shell will guide the water into the machine base.
Same if a leak occurs inside the machine.
The flood switch in the base will then be activated, activating the drain pump and closing all valves if open.
Same happens if the washer recognizes water levels above safety limit and drainig does not reset the safety limit within a certain number of secconds.
This system is active at any point the machine is turned on.
Consequently, the only fault combination of any component between faucet and drain hose leaving the washer that could cause a leak would be both of the safety valves in either hose failing at once together with either the drain pump or the hose it self.
And even then the life long warranty for this system should cover your damage as long as installed correctly.
